95 f250 deisel
Old 01-17-2018, 05:54 PM
wdudra's Avatar
wdudra
wdudra is offline
95 f250 deisel
truck will not crank. i put in new batteries, replaced contector ends at battery and replaced starter relay on fire wall. the wait to start engine light comes on and goes off. when i turn key i get one click. 12.6 volts on batteries.
Old 01-17-2018, 06:03 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Clean all your grounds.
Old 01-17-2018, 06:19 PM
BuddyBarnes's Avatar
BuddyBarnes
BuddyBarnes is offline
And check the starter. It may be dead. How old is the starter?
Old 01-17-2018, 06:23 PM
97-psd's Avatar
97-psd
97-psd is offline
I would have the starter tested
Old 01-17-2018, 06:53 PM
Hit Man X's Avatar
Hit Man X
Hit Man X is offline
Received 1,168 Likes on 949 Posts
My dually cranked comically slow in the 50*F temps with two fresh, high CCA batteries with a beat starter.
Also agree 100% on grounds. Maybe new cables. They can corrode internally!
EDIT - maybe you have a bad NSS. Have you tried to crank at solenoid? Careful if you have manual.
Old 01-17-2018, 08:24 PM
madpogue's Avatar
madpogue
madpogue is offline
Automatic or manual transmission?
Where is the click coming from? Is it a loud CLICK, or just a medium "click"?
Old 01-22-2018, 09:24 AM
wdudra's Avatar
wdudra
wdudra is offline
i checked the grounds they look good and tight. i check continuity between the batteries and the motor it is perfect. I had the starter checked it is good. the clunk is medium and sounds like like engine compartment passenger side.
thanks for the suggestions
Old 01-22-2018, 10:21 AM
farmert's Avatar
farmert
farmert is offline
Had the truck been starting good before the problem started, or has the truck sat for a long period of time? Put a socket and breaker bar on the bolt on the front crank pulley and see if you can turn the motor over.
Old 02-01-2018, 10:45 AM
wdudra's Avatar
wdudra
wdudra is offline
Thumbs up found problem
after replacing the starter relay, cleaning the battery cables and replacing the cable ends i was still having problem. i had battery tested and it tested good. I going back to the starter. I called another shop and the person there told me that the tester is a no load tester and the starter can be bad even when the machine says it is good. So I replaced starter with new one and no more problems. Ever since I got this truck 7 years ago it would crank for a while before it would start. I thought this was just a ford. Come to find out the starter was half dead since I got the truck.
Thanks for all the help and suggestions.
Old 02-01-2018, 03:55 PM
kameronth's Avatar
kameronth
kameronth is offline
Glad to hear you got it figured out.
Old 02-01-2018, 08:18 PM
Hit Man X's Avatar
Hit Man X
Hell yah! Easy fix
johnsteffy
12-09-2010 07:01 AM
StevensPoint
11-26-2008 03:24 PM
liljon4x4
13
04-28-2007 04:39 AM
alpine7572
1997 - 2003 F150
10-30-2005 10:40 AM
stoner51
09-22-2003 10:38 PM
Quick Reply: 95 f250 deisel
