engine info - Ford Truck Enthusiasts Forums
engine info
Old 01-17-2018, 06:47 PM
catimann catimann is offline
catimann is gaining momentum as a positive member of FTE.catimann is gaining momentum as a positive member of FTE.
engine info
Got this from Wiki:
Postwar, it became the V8-69 (suffixed "A" in Fords, "M" in Mercurys), with compression 6.75:1, 100 hp (75 kW), and 180 lb⋅ft (240 N⋅m)
Not much and makes a statement of how far we have come: 2000-2004 Ford Focus, 128 hp (97 kW) and 135 lb·ft (183 Nm)
Interesting but I like the simplicity of the old engine. But I wonder what could be done to get more simple efficiency out of the motor. Lets face it the companies have developed this to get the efficiency and power gains but also to have control and get the money when the computer goes south.
Can anyone tell me where to look for the S/N on the V8 motor?
Old 01-17-2018, 10:42 PM
49fordv8f4's Avatar
49fordv8f4 49fordv8f4 is offline
49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold
catimann, I have been having an ongoing problem with the computer on my Jeep. I'd go back to a flathead Ford with points and condenser in a heartbeat.
There is no serial number/engine number on the engine after, IIRC, 1931, at least in US production.
Mark
Old 01-18-2018, 02:55 PM
FireEngineMike's Avatar
FireEngineMike FireEngineMike is offline
FireEngineMike is starting off with a positive reputation.
No S/N on the engine. The S/N is on the top of the front part of the tranny.
Old 01-18-2018, 05:47 PM
Quote:
I looked there when I bought it and found nothing. Later I took this picture and
and don't see anything either. I am not talking about the truck S/N because I did find that on top of the frame rail on the drivers side.
Per that no my Merc is a Ford because it starts with a 2no. and not a 4no.
49fordv8f4 said "There is no serial number/engine number on the engine after, IIRC, 1931, at least in US production."
I guess the Canadian Mercury mfg also didn't have no's. I have only found "Made in Canada" on my heads but some of your motors have that too.
A friend, who normally knows his stuff said that there are differences between a Canadian made V8 and a US one. I will have to ask and get back to you here.
Old 01-18-2018, 08:46 PM
bernette's Avatar
bernette bernette is offline
bernette is a name known to allbernette is a name known to allbernette is a name known to allbernette is a name known to allbernette is a name known to allbernette is a name known to all
here,s were my serial number is.
Old 01-19-2018, 09:40 AM
S/N on tranny per Bernette's picture. That number was then stamped on the frame rails. No separate engine S/N.
Old 01-19-2018, 04:54 PM
Ok my oldest friend was watching a show and saw something about the Ford flathead V8 being different from the Mercury one. He said it was something to do with the water pump.
Does anyone know the difference? Anyone have pictures.?
This is my trucks V8: I really need to give it a wash.
Old 01-20-2018, 08:39 PM
I found some more info.
Here: https://itstillruns.com/identify-mer...d-7889451.html
and here: Engine Identification
As per this Bernette your motor is a Canadian motor.
Old 01-24-2018, 12:35 PM
Managed to find my motor code. Gives me more indication that I have a mut truck. LOL
Based on my research this is from a 51.
CHeck out these new tires!! StrokinHer01 1999 to 2016 Super Duty 11 01-11-2018 10:38 AM
facts and info of the 240-300 6inarowmakeitgo Ford Inline Six, 200, 250, 4.9L / 300 29 11-17-2017 06:53 AM
Question of the Week: Would you consider the new diesel F150? Patrick R. General Diesel Discussion 32 04-21-2017 09:41 AM
Ninth Generation Body Style (1992-96/97) Turns 20 Years Old in 2012! FORDF250HDXLT 1987 - 1996 F150 & Larger F-Series Trucks 15 01-01-2017 04:50 PM
world’s most powerful six-cylinder diesel engine. 17 Oaks 6.7L Power Stroke Diesel 6 09-02-2016 05:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
