2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Turn on power ports when truck off?
Old 01-17-2018, 05:34 PM
Inicter's Avatar
Inicter
Inicter is offline
I found this with Chevy Colorado's it was just moving a 50amp fuse up one peg.
So when we turn off the truck 2017 F250 the power ports inside no longer charge. Usually a default setting. Can I do this with the 2017 F250 just move a fuse? and the power ports will be active with the truck off and on?
Thank you
Edit:
WOW I see I am not alone out there.... I found the fix for the Chevy Colorado's I drive as work trucks within 5 mins. We charge Printers Phones and Computers in the work trucks, I leave my gear plugged in all the time day and night and never had a battery issue. New Devices stop charging once fully charged now. I hope there is a fix for this... When ones out camping leaving the key on all the time is asking for trouble.
EDIT: This is what I found... QUOTE" I've heard that FORScan can change the timeout of the power points, up to something like 18 hours. Default is one second." Guess that works...
A simple fuse move would have been much easier.
Old 01-17-2018, 10:12 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
Forscan is the solution. The problem is protecting the batteries for starting, even in a diesel with two batteries. Using both 400w inverter plugs will drain two batteries in about 2 hours, because your converting 12 volt to 110 volt AC. As long as the truck is running no problem, I have two alternators totalling 400 amps. I plan to extend mine to 30 minutes, but I can't extend long as cold starts are especially demanding.
Old 01-18-2018, 08:16 AM
scuba413's Avatar
scuba413
scuba413 is offline
So I have forscan and tried all the code plugs to get the outlet to stay on after doors were open. Nothing worked. Bit the bullet last Friday took it to the dealer to get the TSB involving this problem done. Worked great I now have power after truck is off and door is open!
NHTSA ID: 10100518
TSB ID: SSM 46497
2017 f-super duty vehicles built on or before 22-feb-2017 may have timed 12 volt auxiliary power points that disable when the ignition is turned off and a door is opened.
Old 01-18-2018, 09:13 AM
crewzer's Avatar
crewzer
crewzer is offline
Lightbulb
Originally Posted by Inicter
... So when we turn off the truck 2017 F250 the power ports inside no longer charge...
Our truck's power point inside the 40/console/40 front seat configuration stays on for factory-default 75 minutes. I have a high-current adapter plugged into this power point.
Don't know about other configurations; you may have a try some of the others. See OM page 168.
The time out can be adjusted using FORScan.
HTH,
Jim / crewzer
Old 01-18-2018, 04:38 PM
Tom N OH's Avatar
Tom N OH
Tom N OH is offline
I used Forscan & set mine to never time out. No biggie to me because I know better than to use high demand devices without the engine running.
Old 01-19-2018, 05:03 AM
Smoking Joe's Avatar
Smoking Joe
Smoking Joe is offline
I did the same thing and it disabled my auto highbeams. Had to undo it.
Old 01-19-2018, 08:34 AM
crewzer's Avatar
crewzer
crewzer is offline
Question
...So when we turn off the truck 2017 F250 the power ports inside no longer charge. Usually a default setting. Can I do this with the 2017 F250 just move a fuse? and the power ports will be active with the truck off and on?...
Does your truck have the optional upfitter switches? Switches 5 and 6 can be set for "switched HOT always available" mode.
HTH,
Jim / crewzer
Old 01-19-2018, 03:55 PM
Inicter's Avatar
Inicter
Inicter is offline
HTH,
Jim / crewzer
No it's a pretty basic truck but Ill be going in for an oil change next week Ill see if they can do it for me. Thanks for asking, and thanks to everyone for the feedback.
Cheers
Old 09-23-2020, 02:33 PM
wreedZ71's Avatar
wreedZ71
wreedZ71 is offline
HTH,
Jim / crewzer
what about the cigarette power point on the dash by passenger ac vent? Does it go off also after 75mins?
in a 2019 f250
Old 08-20-2021, 06:38 PM
Platiwanabe's Avatar
Platiwanabe
Platiwanabe is offline
NHTSA ID: 10100518
TSB ID: SSM 46497
Do you know what the new parameters are I habe tried everything on several trucks and it doesn't work
ratucker3
2009 - 2014 F150
04-12-2011 08:47 PM
zoso4g
2004 - 2008 F150
03-08-2011 05:45 AM
yorkhorse
1999 to 2016 Super Duty
03-11-2007 08:30 AM
themtb
Electrical Systems/Wiring
06-10-2006 12:23 AM
InboundFX4
01-03-2005 09:08 PM
Quick Reply: Turn on power ports when truck off?
