Dude where did my oil go? - Ford Truck Enthusiasts Forums
Modular V10 (6.8l)
Old 01-17-2018, 03:51 PM
twigsV10's Avatar
twigsV10
twigsV10 is offline
twigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud of
So I start up my 06 V10 this morning and it is ticking badly, shut it off and check oil and there is none. WTH, it dose have 5k on the oil and was checked and only slightly low in the past 800 miles.
Dumped 6 quarts in to the darn thing and wasn't full... No smoke, no leaks it's just gone. Am I doomed?
It's a farm truck and earns its keep and has done so Very well.
Old 01-17-2018, 05:19 PM
super 6.8
super 6.8 is offline
super 6.8 has a good reputation on FTE.super 6.8 has a good reputation on FTE.super 6.8 has a good reputation on FTE.
vandalism?
Old 01-17-2018, 07:14 PM
dkf's Avatar
dkf
dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Don't have much choice but to fill it with oil, run it and try to figure out where it is going. Consuming 6 quarts in 800 miles would be noticeable even with the cats. I'd suspect a good sized leak somewhere or someone sucked the oil out. Short trips can use oil at an increased rate but not that increased.
If it is still running ok after 1000 miles it wouldn't hurt to pull a sample of oil and send it off for UOA. See if there is coolant, bearing material, etc in the sample.
I also would shorten up your OCIs considering how the truck is used. You don't have to run synthetic oil just change it more often.
Old 01-17-2018, 09:06 PM
twigsV10's Avatar
twigsV10
twigsV10 is offline
Runs like a top now and generally sees oil changes around 3-4K but dragging my heels with the cold. It has been doing a lot of short trips and idling but hasn't been an issue in the past.
It wasn't at all happy this morning and I'm afraid I hurt something...
Old 01-17-2018, 10:05 PM
twigsV10's Avatar
twigsV10
twigsV10 is offline
Fudge sickles, have a new filter and oil and I'll see what it does.
Old 01-18-2018, 06:58 AM
Krewat's Avatar
Krewat
Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Any oil in the coolant?
Old 01-18-2018, 10:58 AM
twigsV10's Avatar
twigsV10
twigsV10 is offline
Coolant looks good as well as everything else I can find. Guessing when it was 20 below I did a lot more idle time that I thought, probably have way more hours on the oil than I realize?
I'm going to start writing down the engine hours again. Neglected to on the last oil change
Old 01-19-2018, 07:05 PM
dkf's Avatar
dkf
dkf is offline
Yeah go by engine hours. I always thought going by mileage was a poor way to track maintenance. At least you can see hours on your display, mine does not.
With the temperatures you are seeing I would run a 0w30 oil. I have been running it in mine for several winters now and I can tell the difference. At 0 degrees F I am looking at around a 7-8psi drop in oil pressure at startup with the 0w30 synthetic vs 5w30 synthetic. I was getting as high as 86psi at startup on the 5w.
Old 01-20-2018, 12:35 PM
truckfella's Avatar
truckfella
truckfella is offline
truckfella has a good reputation on FTE.truckfella has a good reputation on FTE.
What's the procedure for checking engine hours?
Old 01-20-2018, 03:41 PM
twigsV10's Avatar
twigsV10
twigsV10 is offline
On 05 and newer SD you cycle through to it on the dash ODM with your trip button. Unfortunately the older trucks never had this feature.
Old 01-21-2018, 05:43 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice guy!
Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.
Whaaaaa?Do tell
Old 01-21-2018, 04:27 PM
twigsV10's Avatar
twigsV10
twigsV10 is offline
On my 06 Super duty if you push the trip button it will show this. I don't know if that's true for any other Ford vehicles.
FYI, the dash was cleaned two weeks ago....
Old 01-21-2018, 08:07 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice guy!
Thatís really cool.
Im pretty sure mine doesnít have that feature. Iíve pushed the trip button many times and it just has Trip A and Trip B.
Old 01-21-2018, 09:53 PM
twigsV10's Avatar
twigsV10
twigsV10 is offline
If I divide 140,000mi by 3206hrs I should be able to figure the average lifetime speed, correct? If so it's around 43.6mph, significantly faster than I was expecting.
Old 01-22-2018, 08:18 PM
dkf's Avatar
dkf
dkf is offline
Originally Posted by Im50fast View Post
That’s really cool.
Im pretty sure mine doesn’t have that feature. I’ve pushed the trip button many times and it just has Trip A and Trip B.
The F-series got that in 05'. I don't know if the E-series ever got it. The E-series never got the 3V and a bunch of stuff the F-series got. Ford neglected several different models over the years and then wondered why sales numbers kept declining on those models, gee I wonder.
Quick Reply: Dude where did my oil go?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
