2011 f350 6.2 no start
01-17-2018, 01:24 PM
on
2011 6.2, Here is what they have done and where it stands. Came with a no start condition, cranks fine. Replaced the fuel pump, module / relay by the evap, crank sensor and tested resistance on cam sensor and they read good. getting fuel coming out of exhaust now from cranking. Help. No codes
01-17-2018, 02:10 PM
Verify spark. If you have spark, verify compression.
01-17-2018, 02:28 PM
am I reading you correctly. YOU NEVER had this engine running ???????
BAD FUEL... try starting fluid..
air, spark, fuel, timing.
verify.. then troubleshoot.
is crank SPEED correct...
real time data from computer..
01-18-2018, 11:18 AM
on
Thanks for getting back
Here is where it stands, I have fuel, power to coils, good resistance on cam and crank sensors. Can't do CKP Neutral relearn due to no start condition. Fuel in tank is new and I put some additive in it. CRAZY
01-18-2018, 12:12 PM
pull one spark plug.. (any one) test for spark.. and how does the plug look
wet,dry,black.white..
if you have a spark plug triggered timing light.. does it flash.. and timing should be within range..
air filter and passageways are clean.
01-18-2018, 08:45 PM
Try pulling driver side kick panel and wiggling the connector next to parking brake.
01-19-2018, 09:06 PM
01-19-2018, 09:31 PM
What about the safety fuel shutoff valve on the passage side dashboard.
01-19-2018, 09:35 PM
If the fuel was shut off, he wouldn't have fuel coming out the exhaust.
01-20-2018, 05:39 PM
Quote:
Originally Posted by
Ron94150
If the OP has gas coming out the tail pipe then a no start condition is the least of his worries.
01-20-2018, 08:32 PM
There is a possibility that if he gets spark that he will no longer have an exhaust.
01-21-2018, 07:22 AM
Bad, Dirty or gummed up injector(s) maybe if you have gas coming out the tail pipe. Would it not do the same as a Float getting stuck in a carb?
wtroger
1983 - 2012 Ranger & B-Series
09-15-2018 12:03 AM
CigarMan2014
1999 to 2016 Super Duty
12-22-2017 04:59 PM
capriceragtop
06-23-2012 10:59 AM
mullin76
13
05-25-2011 07:31 AM
freakboy
1997-2006 Expedition & Navigator
11-06-2009 05:02 PM
