interrupted regen question
You know the Murphy's law story by this point......I did a long highway haul today (350 miles) and sure as **** I hit a regen just as I pulled off the interstate. Interestingly, my dpf was only showing 90% but I hit 500 miles on the nose since the past regen and it kicked on. I know there's been some dispute on whether it will force a regen at 500 miles and mine definitely did today.
Anyway back to my point, my dpf only got down to 80% by time I pulled in and I really didn't feel like driving around just to let it complete. This is the first time that's happened where I didn't finish a regen so just curious if that's bad for the motor? Or should I just expect it will start up again relatively soon and should I make sure and drive to complete the next one? Or does it really matter at all unless I get the "drive to clean" message?
Thanks!
Thanks!
Not likely to do any damage. All that will happens is the truck will monitor, as the % soot goes up and temperature criteria are met, it will begin another clean cycle. If it doesn't complete the cycle several times, it will start giving you messages to drive to complete the cycle. With my winter temps I have never received any messages to drive to complete cleaning cycle. As long as all is functioning correctly no problem.
Received 6,619 Likes
on
I read here on the forum that once the truck is put into Park during a regen that stops the regen process. On my truck that is sort of true. I'll put it into Park during a regen that has brought the DPF % down to 60% at that point. The DPF % will continue to fall while idling. I've had it go to zero once and 25 another time.
Another thing I heard is that if you interrupt a regen and shut the engine off right away that can lead to fuel in the oil. I read it on the Internet, so it MUST be true. I have no solid proof of this. To be on the safe side I let my truck idle for about 5 minutes in Park if I interrupt a regen.
I'm likely putting too much thought into, but I'm OK with that. It gives me something to do.
I interrupted regens all the time on my previous-gen diesels and have done the same with both my 2017 diesels. No issues, ever.
In fact, the 2017 trucks no longer give you a message of "Cleaning Exhaust Filter" so how would an uneducated customer even know a regen was happening?
There's no harm in doing this, but I agree with Jim that even if you want to just pull in the yard and shut down, it's best to let the truck idle in Park 2-3 minutes. Even though the regen "stops" dumping fuel, the temps are so high that it will continue to burn down and usefully reduce your %Full screen. If nothing else, it saves some fuel.
Once you've driven a diesel Ford for awhile, you can recognize a regen by a slightly different engine sound, much more active turbo gauge, greatly reduced fuel economy, and if you're stopped or traveling slow...that burning hot smell.
on
Thanks!
Thanks!
This morning I had a good long hwy commute to a jobs site, so I feel confident that everything worked itself out.
I need to get that DPF screen enabled though.
I've heard that a regen interupted by shutting the engine off will stop the cycle, and another regen will not commence until the DPF hits 99% full again. I was in the middle of a regen when I stopped at the dealer to pick up some parts I had ordered, and the DPF was reading 50% full when I shut off the engine. To my amazement, the regen continued after restarting the truck 20 minutes later, and the DPF was down to 35% full when I got home 4 miles away.
I just hooked up my CTS2 and it shows so many regen points - there are 4 or 5 EGT readouts; it shows the soot level in gal/ltr; it shows if the DPF is functioning or not (on/off) which signals a regen; plus so much more. I like the ability to see all of this stuff and the more I drive it, the more I like it (the monitor). Love the truck. And it has the XL info screen so, the CTS2 has a gold-mine of data. Had no idea regens generate 1300 degrees...I’m in the coal business and that’s HOT! Trover’s right, 15-20 mins @ 75-80 mph does the trick and it’ll shut off. And no harm in a interruption. It’s made to just pick up where it left off.
