F250 1995 vibrations 20 to 50 km/h - Ford Truck Enthusiasts Forums
Old 01-16-2018, 10:36 PM
damien71 damien71 is offline
damien71 is starting off with a positive reputation.
Hi guys,
i have had my truck for over 4 years now and it was running really until few weeks ago, starting to vibrate between 20and 50 km/h when it shifts gear, i guess between the second and third, and it seems like it takes forever to get to the gear.
i serviced the transmission fluid, i changed the filter ( the fluid was dark and stinked like crazy), then it was still vibrating, so i change my spark plugs, it was needed but it sill vibrates..
Any idea ?
Btw, my f250 has an automatic transmission, a 5.8l V8 EFI, and it's a RWD, 208000kms and got tuned up when i bought it in 2013, everything got flushed, serpentine changed, differential flushed, some wiring changed
thanks in advance for your comments
Old 01-16-2018, 11:41 PM
88XLTLariat's Avatar
88XLTLariat 88XLTLariat is offline
88XLTLariat is starting off with a positive reputation.
Sounds like torque converter problem.
Old 01-17-2018, 12:07 AM
Does it mean i have to change it or can i avoid that by doing something else ?
Old 01-17-2018, 12:13 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Where are you located? Any chance you got some ice or snow packed into your wheels?
Old 01-17-2018, 12:16 AM
I'm in Edmonton Alberta Canada, we had effectively some really cold period but would it last that long with some thawing days ?
But if so, were exactly should i check ? Also my long box is empty so i don't have any weight and it's a RWD
Old 01-17-2018, 10:44 AM
Conanski's Avatar
Look at the inside rim circumference for snow/ice buildup.
Old 01-17-2018, 04:27 PM
Hey guys, just a heads-up, i got my truck diagnosed, the tranny is smoked so considering the cost etc, i'm gonna let it go
Information Displays ? Tdraym 2017+ Super Duty 2 09-25-2017 11:07 AM
Vibration Diagnosis Details w/chart sammie0126 Excursion - King of SUVs 12 09-09-2017 01:00 PM
Clicking from axle or driveshaft at 10-40 km/h vibrations at 50-110km/h pat420swed Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 24 07-03-2016 10:20 AM
Unknown Vibration HotrodEnvi 1999 to 2016 Super Duty 4 03-21-2016 11:07 PM
Bad vibrations 2013 f350 (new tires) Softcheeks 1999 to 2016 Super Duty 7 03-14-2016 04:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
