Cracked manifold with code 41
So after trying to figure out why my truck isn't able to get to 65mph, I found a massive crack down the middle of my passenger side manifold. I can hear it ticking as well. After pulling codes I only got code 41 which is system running lean. Could the cracked manifold lead to the o2 sensor indicating the system as lean and cause my truck to lose power when trying to reach highway speeds? It has great low end power though. Any thoughts guy?
A cracked exhaust manifold will trigger a lean code. The unmetered air is interpreted as not enough fuel so the computer keeps dumping in more to compensate. So in reality your truck is actually running pig rich.
A rich fuel mixture will kill a converter in short time. Almost worse than a true lean condition IMHO.
Running rich kills power. It can ruin a converter in short order as well.
Is it THE root cause for your issue? Most likely. Replace that cracked manifold. You should also take a look at the converted while you are at it. A simple "rattle test" may confirm the converter is toasted.
Pull the O2 sensor to look for signs of contamination too. And the spark plugs.
I was wondering if the truck would run rough even in open loop before the o2 sensor realizes there's a problem? If my exhaust is the cause for my problems then shouldn't it only cause loss of performance in closed loop after being warmed up?
Fix what you know is wrong. The EFI system is just that: a system. A single component supplying erroneous feedback causes the entire system to adjust.
You could spend weeks analyzing this or use the Easy Button. Fix what you know is wrong. One less thing in the equation. Do not ignore the obvious.
Long Term Fuel Trims are probably jacked to maximum values based on the O2 sensor readings over a period of time.
So know we find out the O2 sensor isn't even plugged in....https://www.ford-trucks.com/forums/1...into-help.html
That does not imply you do not have to repair/replace that cracked manifold.
By the looks of it whom ever replaced that engine for you did a very sloppy job. Hard telling what other easter eggs are hiding.
itswillist
1999 to 2016 Super Duty
08-05-2017 02:04 PM
DirtyFordTires
Escape & Escape Hybrid
07-30-2011 06:34 AM
4.0 Beast
02-21-2008 09:09 AM
