Cab rotisserie - Ford Truck Enthusiasts Forums
Cab rotisserie
Old 01-16-2018, 09:06 PM
brucelee's Avatar
brucelee brucelee is offline
brucelee is starting off with a positive reputation.
Cab rotisserie
Figured this would help with restoration. I may add additional bracing once I tackle cab corner replacement.
finished (almost) can rotisserie
Old 01-16-2018, 10:08 PM
jniolon's Avatar
jniolon jniolon is offline
jniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant future
nice job Anthony that's gonna help the body work a lot !! clean shop too !!
Old 01-16-2018, 10:35 PM
Carbonarc's Avatar
Carbonarc Carbonarc is offline
Curt in AZ
Carbonarc is starting off with a positive reputation.
Looks very nice and well balanced. I'm starting on my cab in month or two. I'd love to see more detail on the door mounting and dimensions for the balance point. Thanks!
Old 01-16-2018, 11:17 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3 Scotty's 52 F3 is offline
Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.
NICE! I built one for a..............non Ford once. It helps a lot. Great job!
Old 01-16-2018, 11:58 PM
brucelee's Avatar
Quote:
A PO had welded in steel plate over the forward floor pan so I knew it would be nose heavy. Using my auto lift I supported the cab with one of the lift arms under the roof area on each side with a 2x4 and manually slide the cab forward and aft until it appeared balanced. The square tube mounted between the door upper hinge and striker plate is actually made up of four pieces. A longer 2x2 piece with smaller diameter piece inserted into each end. These have a flat plate welded on each end which attaches to the hinge/striker mounts. I found that a solid piece would not work because of the door opening design. The middle is attached to an even larger square tube which allows the CG to be moved forward or aft as needed. I did this because I have another 56 cab with original floors (no additional steel plate added). So if I reuse the fixture on another cab the CG can be changed. Hope this helps. I'll see if I can add additional pics. Not a professional welder but just worked with material I had on hand and worked it out as I went along.
Old 01-17-2018, 12:04 AM
brucelee's Avatar
Quote:
Thanks. I don't have a lot of metal to replace but I still plan on adding additional support on the inside of the cab before I cut out anything. I have no timeline to finish so it just looks cool on the stand anyway.
Old 01-17-2018, 08:22 AM
Greg Rogers's Avatar
Greg Rogers Greg Rogers is offline
Greg Rogers has a very good reputation on FTE.Greg Rogers has a very good reputation on FTE.Greg Rogers has a very good reputation on FTE.Greg Rogers has a very good reputation on FTE.
That's a great job, Bruce. It looks heavy enough that it could be extended to work for a "frame off" restoration of a car, if the need arises!
Wire order for..what is this..91xlt Justin Herrera 1987 - 1996 F150 & Larger F-Series Trucks 1 01-03-2018 03:02 AM
2004 Excursion FOR SALE 130K MILES Samantha Cosgrove Excursion - King of SUVs 10 12-22-2017 10:28 PM
Western Hauler Diesel_Brad Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 12-09-2017 07:37 AM
I upgraded lariat to King Ranch srkr 2017+ Super Duty 17 10-30-2017 11:33 AM
My Almost Dream build Now 4-SALE! almercenter Vehicles for Sale 0 10-18-2017 01:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
