Its 2018---Where you get a re manufactured engine
My machine shop told me that they will lose their temper from being run too hot, his opinion of hot was over 900. I know a few guys with turned up semis that wont go over 900 either for the same reason. Granted, thats 900 after the turbo, so considerably cooler than what would be in the manifold or even up pipe.
The rule of thumb ive always heard is 200, so, i guess that would make it 1100* in the manifold. Would be curious to know of a first hand where someone has two in the different spots. I would vary with setup, due to drive pressure and distance, so its hard to say a real number.
Anyone have any idea how accurate the thermocouples are? I mean if their tolerance is 100 degrees C at say, 1500 degrees C or if the tolerance is closer to 10 degrees? With most thermometers you can use ice-point and boiling point of water to judge the accuracy, but that doesn't work when you are nearing 1000 degrees C instead of 100 degrees C.
And post-turbo is lower yet. Makes it difficult to know much of anything.
This would be something like +-9F at 1200F... not enough to worry about
BTW, be aware of F vs C. 1000C = 1832F; 1000F = 538C
You want to be around 1200F absolute max, not 1200C.
Also, going back to "how high is too high":
Banks Sidewinder Turbo | Banks Power
Top speed at the summit with the stock engine was 47 mph, driving in second gear, with an exhaust-gas temperature of 1150 degrees F. With the turbocharged engine, we crested the grade at 72 mph in third gear, with an exhaust-gas temperature of 1050 degrees F. The lower temperature is an indication that the engine was not overstressed by the turbo installation.
Either way, it just goes to show how good a turbo on an IDI is - more speed, more power and lower EGTs too!
K-type thermocouples are rated at like 0.75% or 2.2C, which ever is higher. According to google.
Banks Sidewinder Turbo Banks Power
1150F being a "stock" N/A measurement, and probably a good max.
All good information.
Thanks for posting it.
mcali2
08-20-2017 08:11 AM
TheRedPheonix
04-22-2015 05:36 PM
FORD MEGA CAB!!!
01-11-2008 11:53 AM
TexsDixieDiesel
03-07-2005 09:34 PM
