dual tanks, rear syphoning gas into front tank - Ford Truck Enthusiasts Forums
Old 01-16-2018, 12:11 PM
birdsgarage birdsgarage is offline
birdsgarage is starting off with a positive reputation.
I have a '86 F150 5.0 efi with dual tanks. The rear tank always fills the front overnight.
The pump in both tanks work but I only have to run off the front because of the syphoning. Lately I have been smelling gas but don't see any. Could a E6TZ9K044A fix this issue?
Old 01-16-2018, 09:30 PM
FuzzFace2's Avatar
FuzzFace2 FuzzFace2 is online now
FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.
Did you get that number from the other post?
If so and you have the same year truck and fuel set up then I would say maybe but that is the switching valve and the tanks filling would be bad check valves at/in the pumps.
Dave ----
Old 01-16-2018, 10:25 PM
dual tanks = rear syphon to front
Thanks Dave and Vjsimone,
So if I can switch my tanks and they work properly, then the E6TZ9K044A (switching unit) is not the problem. I will
consider pulling the bed and replacing the in tank fuel pumps and whatever needs fixed. Until then, I will only use
the front tank. I saw reference to another part # on here, started with F0, can't find it now but was used for a single tank.
I worked at FOMOCO for several years and do recognize some part #'s. fyi, in the E6TZ9K044A, the first character "E"
stands for 1980 and the "6" is the second number of the decade - hence E6 is 1986 and the first year (supposedly) that
the part was built, it could be used in later years but the part # wouldn't change. So F0 would be 1990. the first letter
"B" was 1950, "C" was 1960, "D" was 1970, etc. Not sure what happened after 2000. Hope this helps and thanks
again for the help.
Old 01-17-2018, 09:51 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The switch does have a failure mode where it will pump from one tank and return to the other tank. I bet that is what it's doing, probably not siphoning on it's own overnight.
If you look at the valve it has six lines, supply and return from each tank, and a supply and return to the engine.
Old 01-17-2018, 03:26 PM
Are we talking the same part? E6TZ9K044A
Old 01-17-2018, 06:03 PM
Franklin2's Avatar
The above looks like a single tank unit with a filter in the bottom of it. My single tank 86 ranger has one on it like the above.
They make them with 6 connections for switching the dual tanks. Does yours look like the picture below?
Old 01-17-2018, 07:21 PM
yes, it sure looks like it. It's cold out but slipped under the truck and took a couple of pictures. there are 6 in/out fittings
trying to make out the part #
It does have the filter on the bottom, I have changed it out on numerous occasions. Do you have a complete part # for this? Thanks
Old 01-18-2018, 01:05 AM
sdiesel sdiesel is offline
sdiesel is starting off with a positive reputation.
do be ever so careful pulling the nylon fuel lines when changing out this unit.
they get brittle and disintegrate, making you wish you had your original problem back
Old 01-18-2018, 10:34 AM
thanks, I've been wondering about that
Old 01-18-2018, 01:39 PM
Franklin2's Avatar
Old 01-19-2018, 06:32 PM
I see where there is a F1UZ-9B263-B available and it has 6 ports. No one can seem to answer if it has the cartridge filter on the bottom like mine does. If it does not have a cartridge filter but somewhere I saw a reference to charcoal.. Would I need to figure out a way
to put an inline filter in front of this fuel reservoir? Thanks everyone.
Old 01-19-2018, 08:08 PM
Franklin2's Avatar
In this description on ebay, they say it does not include the filter. So it must take one in the bottom like the original.
https://www.ebay.com/itm/OEM-F1UZ-9B...-/131947614919
'92 F-250 5.8 Idling Way Too Fast At Times Dan_Johnston 1987 - 1996 F150 & Larger F-Series Trucks 2 08-14-2017 09:59 AM
Gas gauge not working Brittanysmith Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 03-26-2017 12:52 PM
1994 gas smell Bikeboy212098 1987 - 1996 F150 & Larger F-Series Trucks 8 02-09-2017 07:38 PM
Dual Fuel Tank Issue SouthernBlues 1987 - 1996 F150 & Larger F-Series Trucks 1 02-02-2017 06:39 PM
Dual fuel tank problem Michael Poss 1987 - 1996 F150 & Larger F-Series Trucks 6 01-01-2017 04:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
