How to lift 86 F350 2WD
Has anyone here lifted a 80-86 F250-350. I found the following kit:
http://www.rockymountainsusp.com/lif...html?c=308&i=0
Is the best most inexpensive way to lift this truck?
Nothing about that looks inexpensive. $800 and $400 more not included. You might check for a 4x4 kit on Craigslist etc. Can't be that different. I see blocks, j-bolts, front coils, radius arm drop downs and stuff. Alot of people use rough country and have a nitpick here and there but it works.
My "cheap" lift kit consisted of f-superduty 2wd front springs, drop pitman arm and rear 5" blocks. However, this was 4wd with leaf spring fronts.
is there any interchange to a coil front suspension you may be able to piece together? Rear blocks are typical, and the drop radius arms are also necessary to keep everything aligned, same with pitman arm.
Sorry if this doesnt help, but just throwing out the possibility of another application that may have the front coils you are looking for.
I totally missed that his truck is a f350. Ignore my previous post about the suspensions being the same. When he said 2wd I just instantly thought f150 while it was plainly there he has a f350.
Bullnose trucks once plentiful and cheep. No rust. Not true now.
I was just searching early today. Here are a few.
https://houston.craigslist.org/searc...auto_year=1986
