2V to 3V - Ford Truck Enthusiasts Forums
Modular V10 (6.8l)
2V to 3V
Old 01-16-2018, 10:00 AM
puppyf250
puppyf250 is offline
puppyf250 is starting off with a positive reputation.
2V to 3V
I searched, and did not seem to find my answer. So, here goes.
I am looking at buying a 2001 F-450, with the V-10, and about 161,000 miles. It is in a tow truck. I am curious if it is possible, or worth it, to swap in a later model 3V engine to get better power. If so is it a simple swap, i.e. all accessories transfer over, maybe just a new harness?
I have had good experiences with the V-10 in the past, but, this is a different application, and wanted a little more expert advice.
Thanks
Old 01-16-2018, 10:14 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
It's possible. If you have enough time and money you can swap in ANY engine into ANY vehicle.
Is it practical? No, it is not. The electronics are vastly different. You'll have a nightmare to get it to work.
Old 01-17-2018, 10:02 AM
Krewat's Avatar
Krewat
Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
You'd be much better off buying a 2005+ truck that already has the 3-valve in it. The 3-valve electronics are completely different, as Mark has already said. If you had an entire donor truck, transmission, dash board, ABS system, etc, you could do it.
Old 01-17-2018, 04:35 PM
rock2610d's Avatar
rock2610d
rock2610d is offline
rock2610d is a name known to allrock2610d is a name known to allrock2610d is a name known to allrock2610d is a name known to allrock2610d is a name known to allrock2610d is a name known to all
What's different?
the throttle body off a 2v will go on a 3v, right?
both have cam and crank sensors.
shouldn't be too terribly hard, 3v V10s don't have phasers, right?
Old 01-17-2018, 04:42 PM
Krewat's Avatar
Krewat
Krewat is offline
Variable-volume plenum.
Cam sensor on the 3-valve is different than 2-valve. Someone a while back did the swap, and always had a code for the cam timing sensor.
And no, the throttle bodies were different and required an adapter to be machined.
Old 01-17-2018, 04:47 PM
Mark Kovalsky
And the fuel and spark requirements are different. A 2V computer isn't going to run a 3V engine very well. So you'll have to adapt the 3V computer and wiring.
wannaBelkhuntin
24
12-29-2017 01:16 PM
Powerstroker123
1999 to 2016 Super Duty
10-24-2017 11:35 AM
Scottt Bealss
05-24-2017 03:27 PM
Jimmy Krizan
01-06-2017 05:09 AM
Ultraboy
07-25-2016 06:23 PM
Quick Reply: 2V to 3V
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
