L99 Power Point in dash??
Old 01-16-2018, 07:16 AM
Supercab's Avatar
Supercab
Supercab is offline
Mine has come loose. Even the slide up door. How do I tighten it all up?
Thanks!
Old 01-16-2018, 09:40 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
My dash is sitn on the workbench. I'll check it out when I get home... About an hr, Cab
Old 01-17-2018, 07:06 AM
Supercab's Avatar
Supercab
Supercab is offline
Thanks Timmy!! Appreciate it!! Just hope I don't have to pull the whole dash to fix it.....Lol!
Old 01-17-2018, 07:15 AM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
I have an aftermarket radio but pulling the dash in mine takes all of about a minute. It's just snapped in there, pull back and disconnect switches and off it comes. Oh, I do have my steering column cover off and I pull the shifter **** off to make it easier.
Old 01-17-2018, 08:35 AM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Agreed, block your back wheels so you can put the shifter in 1, then you can lower the steering wheel which gives you a bit more area to move the dash.
Old 01-17-2018, 09:31 AM
timmyboy76's Avatar
timmyboy76
There's absolutely no way to remove the dash, with a double din in there. Trust me, I felt the agony, lol....Supercab, I ain't lying but I forgot. After leaving the dealership for vsm programming, I hit my bros shop. There is when I realized the hpop leak. I'm heading v out in garage now to start upping things apart. I'll have a pic/write up shortly, boss...
Old 01-17-2018, 05:58 PM
Supercab's Avatar
Supercab
Supercab is offline
No emergency Timmy, your leak needs to be fixed first-WAY more important than my Power Point.
Old 01-17-2018, 06:59 PM
IDI-Charlie's Avatar
IDI-Charlie
IDI-Charlie is offline
IIRC they are held in by three screws. One of mine ended up snapping the threaded portion off, so I had to glue it back in place.
Old 01-18-2018, 11:23 AM
timmyboy76's Avatar
timmyboy76
Yo Cab.. Ok, like idi mentioned, there 3 screws. From the looks of it, if one of the "prongs" that holds the PowerPoint secure, is damaged, then I can see the "slider" being compromised. Other than that, looks to be a 1 unit deal. Possibly a screw can weaken the assy as well...
Old 01-19-2018, 01:25 PM
Supercab's Avatar
Supercab
Supercab is offline
Thanks!! I'll dig into it then.
Second79F250
03-29-2016 11:37 AM
bigreentruck
03-14-2015 10:56 AM
Jon Henry
1947 and Older Ford Trucks
11-10-2005 03:07 PM
fordmtnman
05-23-2005 05:33 AM
Quick Reply: L99 Power Point in dash??
