Misfire mystery
Misfire mystery
I have a 2000 v10 X I just bought. Had an occasional misfire, vw ry subtle, when I bought it at Thanksgiving. Had put about 400 miles on it since due to cleaning carpets and panels. Decided to clean the engine bay. Used some foaming degreaser and pressure washed it at the spray bay wash. Not my first time since I ran a car wash for 21 years. Immediately a terrible misfire situation when i started it up. Figured ijt was water in something. Drove another 100 miles trying to dry it out over the next couple of days. No improvement. Pulled all plugs today (autolite XP) and cleaned them, regapped and reinstalled. 7 of the 10 plugs were white on the tip. 3 were brown. Not oem plugs or coils. May be running lean? Put it back together. On start up there is no misfire. Any load put on the engine starts the sputtering. If i accelerate just above idle, runs ok. Sputters otherwise. TB is clean. New filter. What am I missing?
I would suggest replacing the boots and springs on the coils to see if that resolves your problem. Relatively inexpensive and many have had similar problems that replacing those pieces have fixed.
They may look fine but still be bad. You mentioned that they are not OEM. Mine were also replaced by the previous owner with non-OEM coils and at least 3 have gone bad already. There are many threads and posts that tell you how to find which coil is causing the misfire. When you by new coil packs, I'd suggest the Denso branded ones sold from rockauto. They appear to be OEM with a Denso sticker covering the Ford part number and they cost a fraction of the price that the dealer charges.
Being the incorrect parts would make me a little suspicious as to them causing the miss AND the previous owner's work on it.
Are you fully aware of the earlier heads low thread count and all of the precautions and torque needed for better longevity of new plug installation?
I have had issues with moisture in my COPs after washing my engine bay. Get a code reader and read the temporary codes. It will tell you what cylinder is misfiring. If it were me, I would replace all 10 plugs and boots and replace any misfiring cylinders with new coils.
Check injector clips. They are old and brittle. Loose connection will give a misfire.
Good luck!
Good luck!
Good luck!
Good luck!
rowekmr
04-12-2018 08:12 AM
