Anyone else have similar problem with an OBD2 adapter?
Last night I sat in the truck for about 10 minutes with the key on engine off, adding displays on Torque Pro app which is installed on my joying head unit. I bought a cheap elm 327 android Bluetooth adapter because the head unit couldn't connect $20 odb2 adapter I had previously.
This morning I turn the key on, waited for the glow plug light to go out and then started the truck. The odometer was showing "-----------". The rpm gauge wasn't reading as well.
I shut the truck off and try again. Same deal. I gotta get to work so I drive away (about 2 miles). The rpm spike up a tad and for a second before shifting. At work I shut the truck off, unplug the Bluetooth adapter and all is back to normal it seems.
Now the head unit wouldn't connect to the adapter before I even started the truck. On torque pro all the ocons were lite except the truck icon. Couldn't get the head unit to even see the adapter for connection.
I type the previous text earlier today.
Just went out for lunch and all seems good for now.
Maybe I should try a better adapter?
I have heard that the "mini" ones have issues sometimes.
Here is the one I purchased and still have, never had any problems with it.
https://www.amazon.com/BAFX-Products...eywords=elm327
- Preston
- Preston
I didn't like how far the bafx hung down and was pretty pleased with the mini until now. I noticed through your link we can get a cable for the port. I think I'll combine the cable and android bafx to give it a lower profile.
I think it's definitely talking to something and I agree, it's not going back in. Hauled some stuff off after work and everything seems ok now. We need a "wipe your sweat emoji".
Thanks for the link Preston. I noticed that one is specifically for android. The joying head unit I have apparently will not connect to just any adapter. The bafx was the first one I've bought but it wouldn't connect. I'll check my purchase history to see if there's a part number difference.
- Preston
- Preston
- Preston
rangerxlt02
08-14-2008 08:00 PM
bla1879
05-09-2008 10:03 PM
14psd
07-10-2006 02:10 PM
