Need batteries today! AGM 750 cca or Lead Acid 850 cca?? - Ford Truck Enthusiasts Forums
Old 01-15-2018, 02:22 PM
JT250's Avatar
JT250 JT250 is offline
JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.
The guy at the local battery place said the AGM is rated closer to 1200 cca even though they say 750. Not sure if that is true.
The AGM's are about $35/battery more than lead acid. They have the same 36 month warranty.
What to do??
Old 01-15-2018, 03:48 PM
JT250's Avatar
....Crickets.....
Old 01-15-2018, 03:57 PM
Walleye Hunter Walleye Hunter is online now
Walleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to all
This one is all opinions and has been discussed to death. I go Costco for 850CCA Interstates.
Old 01-15-2018, 04:14 PM
Stebs Stebs is offline
Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.
This battery was posted about earlier in another thread, may have been my odyssey extreme thread. its 930CCA with a 5 year free replacement. order online and go pick up and get 10% off.
https://www.batteriesplus.com/batter...sel/sli65agmdp
Old 01-15-2018, 04:21 PM
JT250's Avatar
I read through that thread. Thank you though. Those are just too expensive for me to justify.
Old 01-15-2018, 04:22 PM
JT250's Avatar
Quote:
We don't have Costco. I have always run 850cca as well, but if the 750 cca AGM is actually closer to 1200 cca like the guy said, I can get them for under $200
Old 01-15-2018, 04:55 PM
Bill Kay's Avatar
Bill Kay Bill Kay is offline
Bill Kay is gaining momentum as a positive member of FTE.Bill Kay is gaining momentum as a positive member of FTE.
Personally I would make him show me the load test showing 1200 cranking amps let alone the Cold cranking amps. I find his statement hard to believe. I have had the regular lead acid 830 CCA batteries for 3 years now with no problems.
There is a small local mom and pop shop that has been there forever and they get unbranded Johnson Control batteries and put there own sticker on it and sell them for $80 each. 3 year warranty is up but still going strong.
Good luck!
Old 01-15-2018, 05:05 PM
Sous's Avatar
Sous Sous is offline
Sous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant future
Do you have the manufacturer and model you can post for us of the batteries. I bought my first ever set of AGM's a couple months ago. They were pricey as hell, but I am hoping that I get 10+ years out of them. Even if I get 6+ years out of them they will have paid for themselves in warranty replacements and time/effort to replace them.
If I were you (based on the information we have) I would go with the AGM batteries.
Old 01-15-2018, 05:29 PM
dn29626's Avatar
dn29626 dn29626 is offline
dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.
I purchased a set of Motorcraft 850/1000 batteries from O'Reilly, Sunday (1/14/18).
Old 01-15-2018, 05:32 PM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
I have the advance auto Duralast gold. Really have not been driving the truck much but had one go bad. They swapped them both out and refunded me the cost of one for some reason i have yet to understand. Even after i asked them, i did not get a good answer.
Old 01-15-2018, 08:08 PM
ranagent ranagent is offline
ranagent is gaining momentum as a positive member of FTE.
I've run Diehard Platinum AGM's in the excursion now for about 40 months, they are still cranking very strong, and it sure is nice not having to deal with corrosion anymore.
This last spring the f350 needed batteries, local Sears no longer stocks the Platinums, so I bought the Oreilly's platinum agm battery. About a month ago when we had our first cold stretch, one of them went bad... They warranted it out, in fact they replaced both when I asked them, but was still a hassle I didn't expect so soon.
Old 01-15-2018, 08:23 PM
ExPACamper ExPACamper is offline
Almost there
ExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant future
I have Autocraft Gold but only getting 2-3 years out of them.
Old 01-15-2018, 09:22 PM
I grease my connections, what's this corrosion you speak of?
Old 01-16-2018, 10:48 AM
JT250's Avatar
I decided to try the Advanced Auto Duralast Platinum. They are AGM 750cca. I got them for about $170 each after discounts. I would have loved to put the ones in that you did, but can spend that on batteries right now. The new AGMs crank the truck over nicely. They have a 36 month warranty.
Old 01-16-2018, 11:08 AM
Sous's Avatar
I took a leap of faith and gambled a bit. I recently conveyed my thoughts on the experiment of buying the high dollar AGM batteries and hope I don't get burnt and made a mistake. A wise man quickly told me that "it is only a mistake if I don't learn from the error of my ways and make the same decision again" or something to that nature.
This is my first time buying "high dollar" AGM batteries. My only knowledge about them is what I know in the way of deep cycle AGM batteries for RV's. They are better than lead acid, but not nearly anything like lithium.
So, I decided to try the AGM's in hopes they last until 2026 or so. If not, then I will re-evaluate my options at the time. Keep us updated on your thoughts on the batteries as time progresses.
RockAuto Now Offers Batteries! RockAuto Vendor Specials, Discounts, Product Announcements & Group Buys 0 01-15-2018 12:47 PM
Dead Battery Revelations Fuzzpuss 6.0L Power Stroke Diesel 51 11-25-2017 05:14 PM
Batteries Sarge261 6.0L Power Stroke Diesel 118 06-23-2016 01:25 PM
Torklift HiddenPower Is Perfect for Extra Battery Power Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 0 04-27-2016 06:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
