SUGGESTIONS? Need New Coil Packs - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 01-15-2018, 10:34 AM
jacecil082
jacecil082 is offline
jacecil082 is starting off with a positive reputation.
Need to replace some COP's on my 06 Navigator 5.4L.
Any suggestions on brand? Would like to try and not break the bank but don't want to use a brand that is no good either.
Old 01-15-2018, 11:15 AM
R&T Babich
R&T Babich is offline
R&T Babich has a great reputation on FTE.R&T Babich has a great reputation on FTE.R&T Babich has a great reputation on FTE.R&T Babich has a great reputation on FTE.
Originally Posted by jacecil082 View Post
Need to replace some COP's on my 06 Navigator 5.4L. ...
Are you sure the COPs need to be replaced?
The boots usually degrade long before the coils go bad.
I've used Denso boots and coils that work well.
I've changed the boots 3 times and still have the OEM coils after 173k.
Some say they are the manufacturer for the OEM Ford units.
Rock Auto seems to have among the best prices for them.
Old 01-15-2018, 02:41 PM
jacecil082
I suppose it could just be the boots. Anyway easy way to test the pack?
Old 01-15-2018, 05:34 PM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
alwaysfords41 is gaining momentum as a positive member of FTE.alwaysfords41 is gaining momentum as a positive member of FTE.
Yes change the boot on the one that is misfiring.
Old 01-15-2018, 05:54 PM
Augusto1963
Augusto1963 is offline
Augusto1963 is starting off with a positive reputation.
I changed all for Accel yellow coils, improved performance and millage, I'm very happy with my choice.
Old 01-15-2018, 08:29 PM
jacecil082
Unfortunately it's not throwing a code so I'm not sure which cylinder it is.
Old 01-15-2018, 10:17 PM
rowekmr
rowekmr is offline
rowekmr is gaining momentum as a positive member of FTE.rowekmr is gaining momentum as a positive member of FTE.
I have heard that before that the boots go bad first. How does the boot attach to the coil?
Can't believe how cheap they are:
Amazon Amazon
Old 01-16-2018, 01:50 PM
pdqford
pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Hmmmmm. So how will you know which COPs to change?
Old 01-17-2018, 11:48 AM
jacecil082
Swapping and testing... LOL
Old 01-20-2018, 09:39 AM
meborder's Avatar
meborder
meborder is offline
meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.
Bite the bullet and do them all.
I did them one at a time for the same labor cost as doing them all.
I tried to save my two newer coils and replaced 6 of the 8 instead of doing all 8. Cost me $100 labor. Later that week when the #4 was acting up I took it back and paid $45 in labor for that one coil.
Lesson learned.
I got my coils from NAPA for about $50 each on the good guy deal. They sell a cheaper coil but get the premium.
Trying to do them one at a time did not work out for me.
Old 01-23-2018, 08:27 PM
Resto Guy's Avatar
Resto Guy
Resto Guy is offline
Resto Guy is gaining momentum as a positive member of FTE.
For 15 years whenever I replaced a faulty coil (with boot), the related plug was replaced with a new Motorcraft plug. The last few years the coil failures became more frequent, like 2 or 3 times per year, usually after extended periods of wet weather.
About a year ago I bought 8 Denso coils and boots, and 8 Motor Craft plugs. Plugs are torqued to 22 lbs.
I can't remember the Expedition ever running so well.
Old 01-27-2018, 09:43 PM
dr67's Avatar
dr67
dr67 is offline
dr67 is gaining momentum as a positive member of FTE.dr67 is gaining momentum as a positive member of FTE.
I had the same problem. Kept eating coils up. Changed the plugs and the coils. Runs like a swiss watch. it was 3 years ago. I used the A/C delco brand from Amazon. it was right around $100 for 8 of them. so far so good.
Glenn54
11-16-2017 07:24 AM
Jarrett Campbell
17
04-09-2017 10:29 AM
hoso50
11-02-2016 11:48 PM
iya0yas
2017+ Super Duty
10-15-2016 08:37 AM
TheBoz71
08-24-2016 11:25 AM
Quick Reply: SUGGESTIONS? Need New Coil Packs
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
