F250 bump stops. - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
F250 bump stops.
Old 01-15-2018, 11:23 AM
7591250sd 7591250sd is offline
7591250sd is starting off with a positive reputation.
F250 bump stops.
Howdy
Will be getting 2018 F250 4x4 6.2 CCSB this spring, to tow our new 5ver, with pin weight in 2200 - 2400 lb range loaded. I plan on getting camper prep package with aux springs. I want to determine at what point aux springs take effect, and if setting up some bump-stop spacers so that when trailer is hooked up, they make contact sooner and still give a decent ride, and reduces sag.. I will have about 600 lbs other payload with 2 passenger's and 5ver hitch, 2 small dogs..
Anybody have a info/pics that may help?
Old 01-15-2018, 11:53 AM
mwheue mwheue is offline
mwheue is starting off with a positive reputation.
Timbren and Sumo both make what you are describing.
Old 01-15-2018, 11:59 AM
wb6anp wb6anp is offline
wb6anp has a very good reputation on FTE.wb6anp has a very good reputation on FTE.wb6anp has a very good reputation on FTE.wb6anp has a very good reputation on FTE.
That will be close to or over max load on a 250, may want to look into a 350 for added safety margin. yes you can tow it but may not be able to stop it. I believe the 350 is only about $1500 more. Id lean more to the 250 being quite a bit over loaded, your talking atleast 3000# of payload, I dont know about the short bed 6.2 250, but my LB 6.7 only has about half that in payload.
Old 01-15-2018, 12:01 PM
First Dually First Dually is offline
First Dually is gaining momentum as a positive member of FTE.First Dually is gaining momentum as a positive member of FTE.
What wb6anp said.
Old 01-15-2018, 12:22 PM
T diesel T diesel is online now
T diesel has a good reputation on FTE.T diesel has a good reputation on FTE.T diesel has a good reputation on FTE.
Quote:
What is the difference in braking between the 250 and 350?
Old 01-15-2018, 12:37 PM
Poncho450's Avatar
Poncho450 Poncho450 is online now
Poncho450 is gaining momentum as a positive member of FTE.
I don't know what the pin weight is. But my 5th wheel camper is rated at 11,400 gross and 8500 empty. So in reality we're somewhere between the 2, probably at the higher end.
I was thinking of Timbrens because I had them on the last 2 trucks. But they didn't have the snowplow/camper package like this truck does. I find that with my camper hooked up I'm still about an inch or better from engaging the overload springs.
My camper use is somewhat limited and short distance so I didn't elect to install Timbrens this time.
Old 01-15-2018, 12:55 PM
J Standard J Standard is offline
J Standard is starting off with a positive reputation.
Quote:
This
Old 01-15-2018, 12:58 PM
Flyct Flyct is offline
Flyct is starting off with a positive reputation.
Quote:
Originally Posted by 7591250sd View Post
Howdy
Every F250 I looked at on dealer lots only had payloads of about 2100-2300 lbs. You will be well overweight when you add hitch weight and passengers.
My F350 Diesel CCSB has a payload of 3500 lbs. An F350 MSRP is $1000 more than an F250.
Here is a payload sticker of a 2017 F250 CCSB that I almost bought. It has a payload of 2291 lbs.
Buy a 350.
Old 01-15-2018, 01:33 PM
I think the diesels have a lower payload, my 6.2L F-250 has a higher capacity than the above sticker?
Old 01-15-2018, 02:00 PM
Yes,
Gas - Diesel about 900 lb difference
F250 - F350 about 1000 lbs difference
And F250 - F350 about $1,000 difference.
Old 01-15-2018, 02:03 PM
JRnCO JRnCO is offline
JRnCO is starting off with a positive reputation.
Yes, because they're heavier.
Old 01-15-2018, 04:12 PM
Poncho450's Avatar
My 6.2 is between that sticker and yours at 3099.
Old 01-15-2018, 04:25 PM
Not sure what the total weight is on what you want to tow, but I wouldn't want to tow more than 10-12k with a 6.2l personally depending on gear ratio. Mine is a 6.2l /3.73 and towing 8k it does great in the mountains, but add 2k and it winds up pretty good to maintain speed. Also adding springs, bumpstops and airbags won't increase your capacity. You still have to stop it safely.
Old 01-15-2018, 04:39 PM
fleming23 fleming23 is online now
fleming23 is starting off with a positive reputation.
Why does everyone continue to mention stopping safely. The 250 and 350 have the exact same brakes. With the exception of the rear axle and rear springs, they are the exact same truck (and even the rear axle can be upgraded to the 350 axle.)
Old 01-15-2018, 05:30 PM
Quote:
A overloaded truck is a overloaded truck! If you surpass its load carrying ability you wont be able to stop it safely rather it be a F-250 or F-350. When talking about modifying the springs etc. people lose sight of stopping the extra load. Ever thought about losing your trailer brakes on a mountain pass?
F250 camper package springs - how much weight before take effect. 7591250sd 2017+ Super Duty 2 01-21-2018 03:09 PM
Sync 3. Ver. 2.3 Whiplash2130 2017+ Super Duty 78 01-04-2018 07:39 PM
Altitude Effect volwing1 Fifth Wheel & Gooseneck RV Towing 13 09-16-2017 01:56 PM
Applied power or lack thereof 17 Oaks 2017+ Super Duty 27 01-23-2017 10:53 PM
Auxillary Springs - What are they nonrev321 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 04-25-2016 07:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
