Is this brake line set up ok?
I am using the CPP firewall set up. I ran one 3/16 line from the prop valve to a tee fitting. Then 3/16 line from the fitting to each of the frt calipers. Should this set up be ok? Or should I run 2 separate lines from the prop valve to the frt calipers? IE: use the frt bottom port to the lh caliper and the upper port (which is now plugged) to the rh caliper?
I have seen it done both ways.
Actually maybe this valve should be called a combination valve, Instead of a proportion valve.
I called CPP and the guy I talked to said I should run the 2 separate lines to the frt calipers, but he wanted to check with someone else to make sure. Then he came back to the phone and said the way I have it is fine.
Any one else have this booster set up and only ran 1 line to the frt??
1972F600
05-18-2017 08:48 PM
zip439
51
01-06-2015 07:01 AM
F-250 restorer
09-22-2010 11:19 PM
NC2X4
27
09-15-2010 10:54 PM
