93' 302 to 351 swap
Old 01-15-2018, 03:11 AM
NotSoNicely's Avatar
NotSoNicely
NotSoNicely is offline
93' 302 to 351 swap
Ive looked a bit, but will my zf5 bolt directly to a 351. If so will it hold? Did they use the same zf5 in both motors? I plan to get a 351 from a 93 f150 or 250. Any other years you'd recommend that might be better to swap that fit? Thank you.
Also planning to turbo it after i get bored.
Old 01-15-2018, 09:58 AM
Conanski's Avatar
Conanski
Conanski is offline
Is this in an F150 or something heavier?
Yes the trans will bolt up.. both of these motors have the same trans bolt pattern.
Old 01-15-2018, 11:28 AM
baddad457's Avatar
baddad457
baddad457 is offline
They used the ZF5 in the F250's behind the 351W, so yea it'll hold up. They put em behind the 7.3 diesels too, though that may have had better internals to handle the extra torque.
Old 01-15-2018, 12:18 PM
NotSoNicely
Yupp its a 150
Old 01-15-2018, 01:08 PM
Conanski's Avatar
Conanski
Conanski is offline
Originally Posted by NotSoNicely
Yupp its a 150
That trans is a Mazda M5OD then.
Old 01-15-2018, 01:14 PM
Conanski's Avatar
Conanski
Conanski is offline
The '94+ 5.8 motors are a bit more desirable for the factory roller cam.
Old 01-15-2018, 02:45 PM
NotSoNicely
I appreciate it, good to know, its got a new trans in it. The stock one died at 700k. Ive got 1.1 million miles on my 302, is wore out and cracked, already welded together once, its pretty far gone. I got a used trans for awhile, and 3 years ago got a brand new trans + clutch of ebay. Dont drive it much anymore. Summer work truck.
Old 01-15-2018, 03:28 PM
Conanski's Avatar
Conanski
Conanski is offline
WOW!!
Old 01-15-2018, 03:45 PM
NotSoNicely
Originally Posted by Conanski
WOW!!
Doin 65+ up a hill in 4th foot to the floor isn't possible right now.. need new engine.
wonderbread55
1978 - 1996 Big Bronco
12-19-2014 10:02 AM
my93
01-16-2011 02:14 PM
1983FORD
02-20-2008 10:13 PM
Rupenthal94F150
01-30-2006 06:20 PM
cjben
04-01-2002 11:07 PM
Quick Reply: 93' 302 to 351 swap
