Strange fluttering sound from air intake ?
Ive got a fluttering sound coming from the air cleaner box, it does increase in speed with an increase in rpm`s. Could this be a bad Idle air control valve?
The filter is pretty new.
Also, I had an oil change not too long ago and the oil is black and does not smell very good.
So the sound is normal,
The oil smells more burnt than gas. I checked it a couple times in the last 2 days and the level is slightly above where it sould be.
I had the plugs changed very recently and they all looked in very good condition, not black at all.
I do have a minor oil leak at the oil pan gasket and I had a leak at the pcv valve grommet but I just replaced the PCV valve and grommet with new (MC from dealer) ones and no more leak.
This may be or may not be related but About a month ago My oil gauge started to move up slightly when I hit the brakes then goes back down when I take my foot off the brakes, The other gauges act normally. I just had A new battery installed Saturday and it still does it just not nearly as obvious.
Not sure about the oil gauge issue though, I might just change the sensor to see if that is the problem, because along with it moving a bit when I hit the brakes the pressure gauge is way lower than it usually is but I do have plenty of oil.
hosenturf
16
03-10-2007 02:53 AM
