New Truck puchase want opinions
so the faster cars are gone, sold them due to various problems that were mostly model related. So this will be my main vehicle and I don't want to end up burning it up .
As far as the truck I know it's big and heavy but i want to know that I can pull out into traffic and accelerate without feeling like I am stressing the engine/trans constantly, the 6.2l 3.73 felt that way,
no real plans on going larger with rims or tires, infact if I order the 2018 it will likely have 18's as the factory 20's I liked aren't available.
The people that claim it is much more expensive to own/operate a diesel have never looked at the actual numbers and they don't consider the resale value.
Depending on the mileage you put on a vehicle and the amount of towing the net cost of owning a diesel over a gas for the first 5yrs/100k miles is not very different.
If you plan to keep a diesel past the warranty period then it could be more expensive if you have a major engine repair.
But if you plan on keeping a diesel truck after the engine warranty expires you haven't looked at the depreciation curve or don't care.
13mpg average on a 6.2L 4.30 gear truck might be optimistic, 15mpg on a 6.7 is very realistic.
But getting 13mpg is optimistic with the 6.2 and 4.30's, I will try searching more to see if I can find other results on that. I know I have seen some video's and there cluster has shown 8mpg but don't remember if those were towing or not.
thanks again,
Diesel is a really personal decision. I went that way for a couple of reasons, we my be adding some larger trailers, I like the way it drives, the re-sale is much higher here for diesel. I would probably also go 350 for the difference if you decide to go the diesel route and you think you need the extra payload. I do, with the extra weight fo the diesel and by the time I put 5 guys in the truck plus whatever the job calls for it is nice to have the extra room on the payload side. Gas or diesel, its great truck you will like it.
I went through the same process before buying my 2018 PSD. Started looking at forums for Ford, GM and Dodge last fall. The gas vs diesel argument is as contentious on the other sites as this one. For me, (personal experience), there is nothing worse than "buyers remorse". Now I just err on the side of - "if it's what I want, that's what I buy". You should do the same. Beware of analysis / paralysis.
Having the diesel actually lowers your rated payload capacity because of the added weight of the engine. My F350 CCLBSRW is rated at 4187 pounds. I don’t believe that a 6.7 can get close to that in a single rear wheel. And with the 4.30 it’s rated to tow the same as a 6.7. The 6.7 might be a second or two faster, thats the only difference.
Right, sorry I didn't say that clearly. When I was referring to "the extra weight for the diesel" that is what I was meaning, with a diesel in the 250 the payload could be to low depending on a persons needs.
Robb81 does make a good point. I did receive $4k-$5k more for my trade because of the Diesel engine. However, I traded it at 88k miles before it could be a financial burden and I wasn’t doing the engine any good because 90% of my driving was short trips... tough on the regen system.
so getting 4-5k more for the trade down the road in my case would mean basically recoup the initial price difference for the diesel engine. by going with a discounted 2017 diesel instead of ordering a 2018 gas. Meaning only difference would be maintenance. i still need to look up the mpg for the gas 4.30 as that will make a difference daily if it's too low then the diesel might be more worth it. Maybe I will just have to change jobs so I can tow things with it more .
Please do not think I'm telling you which to get because there are very solid reasons to choose a gas engine, but operating/ownership cost over the first 5 years/100k miles is not a significant factor.
When I was first looking at 17 Super Duty’s, I initially was looking at a F-250 6.2 with 4.30 gears, 4x4 CCLB.(They were hard to find on dealer lots too) I’m planning to use a new truck primarily for towing including a big slide in camper, race car 15k trailer, and in the future a 2 or 3axle 5Th wheel and the occasional gooseneck equipment hauling. Having said that, the F-350 was where I needed to go capability wise and I’m a little partial to duallys for their added safety so it won out. I also liked some of the standard features the DRW comes with,clearance lights, running boards,integrated brake controller, including an optional limited slip rear instead of an E-Locker and hydroboost brakes. It pretty much all comes down to preference and what the end use will be. Resale was the last factor I considered but I did ponder selling a used gasser dually could be a hard sell?
#28
If the NADA trade in value is $6600 higher on a diesel over a gas there is till no real gains because the gas option is still $7-8000 cheaper up front. I could care less what engine anyone has cost of ownership in the end is usually close, as long as there are no major repairs in the life of the vehicle. Maintenance is more expensive and repairs are typically higher on a diesel. Just food for thought
#29
I personally don't see the upside to the diesel unless you are heavily freighted on a daily basis, or hauling a large heavy fifth wheel frequently, which in most cases will put you in a duel rear wheel 350 or higher. That extra power and torque would be great in those applications.I just can't see paying all the extra costs, including initial purchase price, more oil, fuel additives and filters, two batteries etc. Not mention cold weather aggravation, and other aggravations. There is just not enough benefit (in my opinion) to justify the additional costs and aggravations unless the vehicle is being used as described above.
Seems like there is a lot more to go wrong based on another thread regarding Technical Service bulletins. I get the feeling that big brother is doing everything he can to make diesel engines not run. This is all just my opinion which is what the subject of the thread asks for...
https://www.ford-trucks.com/forums/1...d-recalls.html
