Frame width? - Ford Truck Enthusiasts Forums
Frame width?
Old 01-14-2018, 09:48 AM
Kelley D's Avatar
Kelley D Kelley D is offline
Kelley D is starting off with a positive reputation.
Frame width?
I'm having a hard time finding a class 3 hitch kit for my f150 reg cab, 4x4, long box. All the kits are 34" wide. I can't get near the truck to measure but it know it's wider. Anyone know that number?
Old 01-14-2018, 01:43 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
If you open the pdf in this thread, it says 35.5 inches from hole to hole on the back side. I bet 34" would work if their frame brackets turn to the inside.
https://www.ford-trucks.com/forums/1...-diagrams.html
Old 01-14-2018, 02:34 PM
Kelley D's Avatar
82 f150 4x4 reg cab long box frame width is 37.25"
I ended up crawling through the snow and under the back of the truck just now. It's 37.25" outside to outside.
I know the 34" hitch doesn't work because when I held it up to the frame it complete fit between the frame rails.... Way off.
Old 01-14-2018, 02:50 PM
Kelley D's Avatar
I wish I could edit this thread title to say 82' F150 Frame width is 37.25".
Old 01-14-2018, 05:15 PM
FuzzFace2's Avatar
FuzzFace2 FuzzFace2 is offline
FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.
I found mine for my 81 F100 4x2 on CL local to me Reese #37096 multi fit
I like to get my trailer equipment thru Etrailer hereis a link to hitches https://www.etrailer.com/hitch-1982_...250,+F-350.htm
Dave ----
Old 01-14-2018, 10:29 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Quote:
You can do that; use the Advanced Mode editor.
Old 01-15-2018, 09:35 AM
Franklin2's Avatar
Dave ----
I am curious how wide the cross square tubing piece is on that hitch above.
Just in case someone needs this info, I had a bolt together hitch like the above on my 1980 f150(I did not have the adjustable cross-piece though). The 1980 went down and at that time I had a 53 f100 I put on the road. I needed to tow a car home for the engine so I could put it in the f150. I took the hitch off the f150, turned the outside frame brackets around so the ears pointed inward, and it fit perfectly on the old 53 frame so I could pull the car home.
Old 01-15-2018, 09:37 AM
Skip1970's Avatar
Skip1970 Skip1970 is online now
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
you could just put a highlift jack on it and bend it apart more
Old 01-15-2018, 11:13 AM
Kelley D's Avatar
Thanks for that.
Are you sure?? Lordco said that part number was 35". Did you have to modify anything (other than drilling frame).
Thanks again!
Old 01-15-2018, 06:43 PM
FuzzFace2's Avatar
Next time I am out in the garage and I remember I will measure it.
When I found on line the install papers my truck was 1 of many fords along with the other makes.
Thanks for that.
Thanks again!
I don't remember off the top of my head but if I had to drill any holes & think it was only 2.
Well looked up my post and it was 4 - 1/2" holes I had to drill but was not bad as I have the bed off.
Dave ----
Old 01-15-2018, 07:09 PM
Franklin2's Avatar
I remember drilling some holes also. I believe I got a large drill and then sat it on top of a floor jack and used that to push it up through the frame. I do remember having to get gloves, the hot metal filings do no good to your bare hands holding the drill below.
Old 01-23-2018, 01:13 PM
Kelley D's Avatar
Delete me!
Old 01-23-2018, 07:34 PM
FuzzFace2's Avatar
Ok I think I got what you asked for.
From flange to flange where the square tube is was 31.5"
That is straight across the square and not with the bow.
Is that what you wanted. If not when I get back out again (hope this weekend if I don't have work) I can get them.
Dave ----
Old 01-25-2018, 04:43 AM
Kelley D's Avatar
Curt part# 13310 fits my 82 f150 reg cab 4x4 long box
Curt PN# 13310 fit. I wish Curt would've just shown the dimensions in the specs. Could have saved us a lot of BS.
Lift Help 2fifty 1987 - 1996 F150 & Larger F-Series Trucks 5 01-25-2018 04:29 AM
serpintine belt kit Cg willie Willie 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 03-06-2017 08:00 PM
leveling kit roddog101 1997 - 2003 F150 1 11-03-2016 10:04 PM
Lift Kit? Richwon4 Excursion - King of SUVs 2 05-21-2016 07:01 AM
Master body fasterner kits 67nukeford 1967 - 1972 F-100 & Larger F-Series Trucks 0 03-28-2016 11:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
