2009 F250 5.4 or 2013 F150 5.0 for this load? - Ford Truck Enthusiasts Forums
Old 01-13-2018, 04:15 PM
1986F-150
1986F-150 is offline
1986F-150 is starting off with a positive reputation.
2009 F250 5.4 with 4.10 gears -v- 2013 F150 5.0 with 3.73 gears. Both 4X4.
6,000 pounds fully loaded TT and 1,000 pounds in the bed .
Which would you rather tow with? We like back roads and rarely go
over 60 MPH .
Also will there be much difference in real world MPG ?
Old 01-14-2018, 01:00 PM
crop harvester
crop harvester is offline
crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.
I would normally pick the F-250,but would consider the F-150 if it was expected to be a daily driver 95% of the time.
Old 01-14-2018, 04:05 PM
Rustofer
Rustofer is offline
Rustofer is starting off with a positive reputation.
Between tongue weight, bed load and passengers, the F-150 could be beyond maxed out on its payload, depending on its spec.
Old 01-14-2018, 08:55 PM
riddleswest
riddleswest is offline
riddleswest is starting off with a positive reputation.
I have a 25ft Jayco TT with an 8200 GVW. Fully loaded with approx. 1000 lbs of gear in the bed, I'm still 2000 lbs below the GCVW rating of my 2011 F-150 SC Ecoboost with 3.73 gears and the Max Tow package. However, on the advice of this forum I got my set up on the CAT Scale and discovered that I'm over the GVW rating on the rear axle by about 200lbs. I've since upgraded to a 15k rated Reese Strait Line hitch that should theoretically transfer more weight to the front axle. However I haven't gotten back to the scale yet. Anyway my point is...my F-150 handles this load fantastically. Plenty of pulling power, plenty of stopping power and minimal trailer sway.
Old 01-15-2018, 09:32 AM
seventyseven250's Avatar
seventyseven250
seventyseven250 is online now
seventyseven250 has a brilliant futureseventyseven250 has a brilliant futureseventyseven250 has a brilliant futureseventyseven250 has a brilliant futureseventyseven250 has a brilliant futureseventyseven250 has a brilliant futureseventyseven250 has a brilliant futureseventyseven250 has a brilliant futureseventyseven250 has a brilliant futureseventyseven250 has a brilliant futureseventyseven250 has a brilliant future
This is a tough one, I have had the 5.4L engine 3 times, and I'm hoping never to make it 4.
For sure that newer F150 will be better unloaded, and the 5.0 engine has an excellent reputation.
If it's 100% for towing, it's a toss up. If you do much unloaded driving, the 2013 5.0L engine would win no problem.
Old 01-15-2018, 10:37 AM
Buliwyf
Buliwyf is offline
Buliwyf is gaining momentum as a positive member of FTE.Buliwyf is gaining momentum as a positive member of FTE.
250 for sure.
Mcneil239
2009 - 2014 F150
06-07-2017 01:30 AM
rgs4x
Ford Truck Parts for Sale
12-24-2014 11:53 PM
1Aauto
Vendor Specials, Discounts, Product Announcements & Group Buys
12-17-2013 01:50 PM
ihbond
1999 to 2016 Super Duty
10-26-2013 09:14 PM
Gigem08
12-08-2012 01:38 PM
Quick Reply: 2009 F250 5.4 or 2013 F150 5.0 for this load?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
