2018 Powerstroke PIDs - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 01-18-2018, 08:00 PM
SaintITC
SaintITC is offline
SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.
Originally Posted by Tugly View Post
10 characters
There, I fixed that for ya.
Well, 13 characters. And this would be funnier with a strikethrough font.
  #32
Old 01-19-2018, 06:07 AM
Tugly's Avatar
Tugly
Tugly is online now
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Originally Posted by timmyboy76 View Post
....Tugly, everything else is good. How critical is the (0x) before the pid #....
0x? I thought all my stuff was a 22 prefix... I'll look again.
Some time ago, I discovered another way to type nothing into a post. If you look at that post again, you'll see what I mean.
  #33
Old 01-19-2018, 06:34 AM
Tugly's Avatar
Tugly
Tugly is online now
OK... I found the problem. I am such a boob at times... that's the problem.
I was using Open Office spreadsheet to edit the files, and it corrupted some of the information in there when I saved to a CSV file. On top of that, Torque Pro added the 0x in the formula when I exported it... that wasn't me. I have deleted the corrupt file, and replaced it with a file that I repaired with Notepad. Since Notepad doesn't lay out the info in a way that's easy to spot errors, I can't say I didn't miss something... but I proof read what's there.
While I have been delaying the shift, I have now been given the reason to yank the antiquated Open Office out of my old laptop and install Libre Office.
  #34
Old 01-19-2018, 08:23 AM
Sous's Avatar
Sous
Sous is online now
Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.
Office can be sketchy at times. My wife is in the finalizing stages of publishing her first book which she wrote on Office 2010. I helped her edit some of the content with Office 2016. Although it is the same file, when you open the document in Office 2010, it is not the same formatting or even some of the words are swapped out. It took us a couple of hours of fighting with it, but in the end we just upgraded to Office 2016 through the house.
Microsoft is very bad for your health, mentally and physically.
Thank you for taking the time out of your schedule to make our lives easier.
  #35
Old 01-19-2018, 11:44 AM
Bran_SVT
Bran_SVT is offline
Bran_SVT is starting off with a positive reputation.
Well, my no data issue is now solved.. Turns out it was the OBDII adapter... I had the KOBRA one from amazon and it did not work with the extended PIDs. I tried the BAFX one from amazon and it worked perfectly...
  #36
Old 01-19-2018, 11:52 AM
Dan V
Dan V is offline
Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.
Originally Posted by Sous View Post
......but in the end we just upgraded to Office 2016 through the house.
Was quite comfortable on Word 2010....but oh man, do I dislike 2016.
  #37
Old 01-20-2018, 06:39 AM
Tugly's Avatar
Tugly
Tugly is online now
Libre Office, guys. I can read, edit, and save files to/from MS Excel of every era. I can't swear to the compatibility with other MS Office products... like Word, but if Excel is an example - I'm sure they're all fine. I use spreadsheets, PDFs, emails, and texts... that's about it.
  #38
Old 01-30-2018, 04:10 PM
Tugly's Avatar
Tugly
Tugly is online now
I take it there have been no more complications since my last revision to the files?
  #39
Old 02-01-2018, 08:10 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is online now
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
My EOT was a few degrees higher than iat, but that was just cat first start up. Noticed though, TFT(which v there's 3 of them), none give me trans temp...
  #40
Old 02-01-2018, 09:55 AM
Tugly's Avatar
Tugly
Tugly is online now
I suggest adding Torque Scan and look for the PID in there. I'd like to know what's different from my PID.
  #41
Old 02-01-2018, 11:25 AM
L-ight
L-ight is offline
L-ight is starting off with a positive reputation.
Subscribing to this thread. I picked up a Android headunit with a BT OBD2 port. Will be purchasing the Torque pro app once I have it installed in truck. Is it pretty straight forward on getting the gauges I need setup/operate?
  #42
Old 02-01-2018, 11:40 AM
ExPACamper
ExPACamper is offline
ExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant future
I've used that to find PIDs on OBDII vehicles, but never had ANYTHING show up on my 2002 Excursion?
  #43
Old 02-02-2018, 07:52 AM
Tugly's Avatar
Tugly
Tugly is online now
Head units vary widely. Some work just like a tablet and you can link to a laptop via Bluetooth, or you can plug in a thumb drive and transfer all the files to automate the process. Others will only allow media (music and videos) to flow out of a thumb drive, and only mirror a smart phone over the Bluetooth.
Android head units are way more likely to be used like a tablet, so this might be as simple as downloading the files from my first post and placing the files on the head unit the way I did my tablet and phone.
The only Excursion work I've done was with my older version of AE, and that worked just fine. AE has its own scanner that fires up any time it hooks up to a vehicle not stored on the hard drive. Maybe PATS has something to do with the blocked scan... maybe the scanner or Torque Pro has an option/setting that needs clicking. I dunno... I don't have an Excursion at my disposal to tinker with.
  #44
Old 02-03-2018, 09:58 AM
unleashd's Avatar
unleashd
unleashd is offline
unleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud of
Rich
Thanks for the hard work in putting these PIDs, dashboards etc. together. Finally getting around to setup a few gauges on the old Samsung note phone here. Once I get the F650 dash configured, I am planning to make space for a 8" Samsung tablet to be mounted on that along with a few switches for lights etc. Here's a WIP screenshot. I do have some duplicates in there. Display size Tiny is too small to read at night, and Small takes up a lot of real estate. Going to test this for a few days before making other adjustments.
Landscape view
Portrait view
  #45
Old 02-03-2018, 08:38 PM
coax9952's Avatar
coax9952
coax9952 is offline
Athletic Supporter
coax9952 has a very good reputation on FTE.coax9952 has a very good reputation on FTE.coax9952 has a very good reputation on FTE.
Too Much! Too Much! That screen makes My brain hurt!
Quick Reply: 2018 Powerstroke PIDs
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
