02 E450 7.3 stalling now no start
Truck began stalling once in a while but only after getting hot. Eventually code came up for cam sensor. Replaced sensor Thursday night with updated sensor. Same issue. Cam code returned after driving around the block.
After doing some research it appeared the IPR could be the culprit (stalling once at operating temp) so that was replaced last night.
Truck started first time rough then stalled. I was able to run a key on engine running test but no codes. It will now not restart.
I have pulled airbox back off to see if I bababooyed something or unplugged something but I cannot see anything that I could have done in there.
Any suggestions?
Any suggestions?
I had to work almost blind so maybe I misaligned.
I know this I probably a bobo mistake on my part
I'll try to get a picture of how it is installed now.
