Should I start replacing parts or wait until they fail? :) - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 01-12-2018, 09:49 PM
NICKSAN NICKSAN is offline
NICKSAN is starting off with a positive reputation.
1994 Club Wagon, E4OD, 5.8 Just crossed over 227,000 miles.
Knowing that the alternator, Distributor and all the smog equipment, (EGR valve, Air
Pump, Cats ETC..) Fuel pump, Fuel pressure regulator, Fuel Injectors, Etc are original
and are going to fail eventually, maybe any day, I am considering a plan to start
swapping out parts before they fail. I figure I would start with the Fuel Pump and FPR
then move on to the smog stuff.
This is my DD and I have no other vehicle, that is the reasoning behind this idea.
What do y`all think?
Old 01-12-2018, 09:58 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
It's called "preventative maintenance". But don't bother with the injectors, feed it clean, quality fuel and those will last forever. They're electric solenoids, they don't seem to wear out. They'll get gummed up and stick with crappy fuel though, but are pretty easily cleaned with a fuel detergent. The smog equipment will fail before any of the other stuff.
Old 01-12-2018, 10:42 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
The biggest problem these trucks encounter is age, that leads to materials fatigue such as cracked and broken vacuum lines, rubber belts and hoses. Smog system components will fail but they won't leave you stranded, a clogged fuel filter might though so as already mentioned just keep up on the maintenance and you should be good.
Old 01-13-2018, 01:35 AM
fordman75 fordman75 is online now
fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.
Ever heard the saying "If it aint broke don't fix it"? Unless you have money to burn or just like working on it constantly don't replace stuff until you have to ( except maintenance items ) . Now if you see something like your hard brake lines looking really rusty. Then that's a different story.
Don't go just replacing working parts. Stuff like the fuel pump or alternator leave alone until they fail. If you want to buy them, fine but why change them until you have too? If it runs and drives good, don't mess with it! Just take care of maintenance items. Belts, hoses, vacuum lines, filters, fluids, etc. A lot of replacement parts are poor quality. I've had replacement parts that were bad right out of the box. And plenty that failed not long after they were installed.
What I do is, when I need to do a repair. I group the repairs together. My 96 E250 with a 351W/E4OD has around 250,000 miles on the van, with the original engine. When I have an issue I replace as many parts that are in the same general area. Like my water pump started leaking. And I know from past experience that there's a good chance a bolt or two will break off, whiling removing it. So the broken bolts mean I will be pulling the timing cover. So I'm going to replace the waterpump ( and mounting bolts ) , pull and replace the balancer( rubber isolator showing cracks ) and pull the timing cover and replace front seal and the timing set. That way when I'm done the front of the engine is set to go. And if the cooling system is drained that is the time to replace the thermostat, hoses, etc. When you have to do something like pull the timing cover. It's just plain stupid not to throw in a new timing set on a high mileage engine.
And I wouldn't mess with the cats until it acts up ( plugged cat ) or you need some exhaust work. Then replace the cat/s. And if you want to you can upgrade to a high flow one.
Old 01-13-2018, 01:14 PM
Agree with you on poor quality replacement parts. It's a crap shoot now, even with name brands. As for the timing set, that's a different story. Most of the late model SBF's came with a double row-roller chain set, which doesn't wear out like the older flat link chain sets. If you have the roller chain already, leave it alone. They stretch slightly at first then run that way for years afterwards. I'm running a Cloyes Tru-Roller O.E. set in my 331, bought it for $25 at O'Reilly's 14 years ago. Went into the engine last year to change a bent rod and that timing set was still like new, with only a slight amount of slack. And ditto on the balancer. I've run old ones with the rubber cracked for years. If they're really large cracks, then replace it, otherwise if they're tiny cracks, that's no reason to be alarmed.
Old 01-13-2018, 02:42 PM
I really dont want to be stranded by a failed alternator or fuel pump. Those would be the type of things I would do first.
Thanks for the tips and comments.
Old 01-13-2018, 03:19 PM
A failed alternator isn't going to strand you. They stop charging, then you have until the battery's charge runs dry til the engine will quit running. Best thing about these is the alternator is really easy to change. 4 bolts holding it to the bracket and the belt, which is removed using a breaker bar and socket to release the belt tension. Once that's off, then the 4 bolts holding it to the bracket come off then unplug it. The fuel pump's not easy to change. I wouldn't do it until the pump quits. Tank has to be dropped, van has to be lifted to drop it. If you do, replace the filler hose while doing it. They get dry rotted and then leak. Don't buy the factory hose, damned expensive part. Better off buying a radiator hose that fits to replace it.
Old 01-13-2018, 04:36 PM
If you are so concerned go ahead and replace them. But that doesn't mean you won't be left stranded by the new ones. I personally think your nuts for wanting to change the fuel pump before it goes bad. I hate dropping fuel tanks! Just be prepared changing parts doesn't guarantee against break downs. And this is coming from a person that is completely rebuilding a van bumper to bumper ( my 89 E350 ) .
If it was me and I was so worried about being stranded. I'd buy a new fuel pump and alternator and carry them in the back of the van. But dropping the tank on the side of the road is not fun either!! Like baddad457 the alternator is pretty easy to change. But I still wouldn't change it until you need to. It can be changed just about anywhere as long as you have the replacement part and some hand tools.
I think what you should invest in is a AAA card/membership!! Then if you do break down, you call wait an hour or two for the wrecker to show up and they will tow the van. I never leave home without it!! And if you ever do need a tow, that one tow will more then pay for the membership.
Quote:
I would say that would be true if my van only had 100,000 miles on it. But at 250,000 hard worked miles, I'm changing the timing set when I have the timing cover off. I already bought the Cloyes roller set for it. It's way too much work, to have it torn down that far and not change the timing set. I really don't like doing jobs twice.
And I waited about as long as I could on the balancer too. It started to develop a slight wobble to the outer ring. So it's definitely time to replace it. Before I loose it. The down side is this is a 96 so it has the crank sensor too. I haven't dealt with changing the ones with the exciter ring. And the replacements don't come with the exciter ring. So I have to check and see how it's installed on the balancer.
Old 01-14-2018, 05:52 AM
Im50fast's Avatar
Im50fast Im50fast is online now
Just Wannabe Acknowledged
Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.
I agree with these other guys. Drive it til it breaks.
My 2007 E350 has over 330,000 on it and still has the original alternator and starter and fuel pump. I am amazed how electric motors like these Have not worn out the brushes at this mileage. Absolutely amazed.
It on the 3rd HVAC motor though...
Old 01-14-2018, 09:12 AM
wiskeyVI wiskeyVI is online now
wiskeyVI is starting off with a positive reputation.
I recall reading somewhere, when I had a chance to get a V10 E van, that the Modular engine was designed to be a 400k mile engine.
Old 01-14-2018, 10:02 AM
Not sure but the alternator may not have brushes. Fuel pump doesn't, its a solenoid type pump.
Old 01-14-2018, 02:43 PM
Im50fast's Avatar
Quote:
I recently read it was designed for 300,000. Either way, great.
Old 01-14-2018, 07:20 PM
My 99 SD F250 has 330K on it with the 7.3. Still going strong showing no signs old age. Runs rings around a V10
Old Yesterday, 06:36 AM
Im50fast's Avatar
Well why donít your take your blasphemous comments over here:https://www.ford-trucks.com/forums/forum31/
Old Yesterday, 10:00 AM
kgmkgm kgmkgm is offline
kgmkgm is starting off with a positive reputation.
Had to replace my radiator in my 94 w/ 225K on it, so I did the whole she-bang. I didn't think about the damper though so maybe I'll do that sometime. Had the shop do the water pump, timing case, timing set, all new hoses, radiator, t-stat, fan clutch, etc.
Luckily 2 months later I drained the battery too.
Fresh fluids, and the thing runs like a champ.
Fixed vac leaks failed smog Rij1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 21 12-06-2017 12:42 PM
CA SMOG Problems Njstern87 1999 - 2003 7.3L Power Stroke Diesel 33 10-20-2017 04:12 AM
94 f150 302 smog pump bypass belt size mustangfanatic03 1987 - 1996 F150 & Larger F-Series Trucks 3 06-09-2017 04:57 PM
Won't start after replacing parts junkyjay 6.0L Power Stroke Diesel 4 02-17-2017 12:59 AM
NO CEL...EVER, need to pass SMOG, Please Help - Truck Runs Great nossliw 1999 - 2003 7.3L Power Stroke Diesel 6 11-16-2016 07:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
