Fuel Pump Replacement - Anythign Else at same time? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Reload this Page >
Old 01-12-2018, 07:29 PM
davlun
davlun is offline
davlun is starting off with a positive reputation.
Hello,
I have a 1999 F250 (not superduty) 4WD extended cab that needs a fuel pump.
Couple of questions:
1) anything else I should replace at the same time?
2) is the fuel pump and sender all one unit?
3) should i put something on the bolts when re-assembling to help keep rust down?
Any tips on making this easier for a novice?
Thanks. Not a mechanic, just need to get fixed and save myself some money by doing it myself.
Old 01-12-2018, 07:58 PM
Chad T. Keogh's Avatar
Chad T. Keogh
Chad T. Keogh is offline
Chad T. Keogh is starting off with a positive reputation.
It is a minor thing, but when I had my original fuel pump, I could drive for almost 60 miles before the gauge would even start to move from the "F". After it was replaced, the sending unit must have been a slightly different angle, because it starts moving from the "F" in about 5 miles. I know I am not using any more fuel, but it just is a psychological thing seeing the guage start to drop so soon. Check your float height before you bolt it in.
Old 01-12-2018, 09:49 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
changed the fuel filter.
check condition of the fuel tank straps before you start-- may need new ?
Old 01-14-2018, 02:32 PM
bren_tx
bren_tx is offline
bren_tx is starting off with a positive reputation.
On my old truck, I always changed the pump by taking the bed off. I have a f250 like you, and I decided to drop the tank. What a giant PITA! You cannot drop the tank very far because of all of the hoses that connect to it...so you have to disassemble and reassemble basically blind. I will never again drop the tank. Find a buddy and pull the bed off.
I second changing the fuel filter. Also inspect all of the rubber hoses. Replace any that are cracked and worn.
Old 01-15-2018, 02:49 PM
davlun
davlun is offline
Thanks for the feedback.
Picked it up from shop this weekend, unfixed. Will crawl under next weekend and see which seems more rusty, prone to failure before I start.
Learned something already, thought that the fuel pump was separate from the sender, sounds like they are all one unit... glad I posted my question.
thanks,
davlun
Old 01-15-2018, 02:53 PM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
Sam I Am has a good reputation on FTE.Sam I Am has a good reputation on FTE.
It is all bundled into an assembly, but the pump can be replaced separately.
I prefer to drop the tank and clean it out. What if you pull the bed and the tank needs cleaned? Or what if the straps are ready to fail and need replaced? That will require the tank to be dropped anyway.
Old 01-15-2018, 05:53 PM
steve(ill)'s Avatar
steve(ill)
Also, I did a 2006 CREW CAB.. pulled the bed and the pump unit was still 50% covered by the rear wall of the cab... Had to drop one end of the tank anyway....So look at the location of the pump if you just plan to pull the bed.
wharthog
12-21-2017 02:43 PM
RJL1
18
02-18-2017 04:07 PM
RJL1
01-31-2017 06:59 PM
Jymmm
1997-2006 Expedition & Navigator
19
09-07-2016 11:53 PM
IPrez85
1997 - 2003 F150
03-28-2016 03:35 PM
Quick Reply: Fuel Pump Replacement - Anythign Else at same time?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
