Help for a friend with a stroke
No. The **** has a clip inside the plastic that holds it on the shaft, but it can be forced off
The switch is held in the dash with the nut you see when the **** comes off
nothing else is holding the switch in, except time, and gunk from it being there so long
You can push on the switch once the nut is off, and it should "break "loose
Then just push the thing through the hole with your finger, reach froom behind, and wiggle the whole mess down to where you can unhook the harness
ManI wish you lived nearby, I'd sure like to help, or at least provide morral support
Received 3,090 Likes
on
on
on
Marketmanohyeah1
04-01-2012 07:45 AM
86sixbanger
25
09-16-2009 09:57 PM
Gary E
02-20-2007 12:39 AM
PhilipM3
06-08-2002 12:22 PM
