1978 - 1996 Big Bronco
Help for a friend with a stroke
Old 01-13-2018, 01:37 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Can anyone tell me if there is a clip holding the wiper switch on?
Or does it just pull off?
Old 01-13-2018, 03:20 PM
skuzzybucket's Avatar
skuzzybucket
skuzzybucket is offline
don't play well w others
skuzzybucket has a superb reputationskuzzybucket has a superb reputationskuzzybucket has a superb reputationskuzzybucket has a superb reputationskuzzybucket has a superb reputationskuzzybucket has a superb reputationskuzzybucket has a superb reputationskuzzybucket has a superb reputationskuzzybucket has a superb reputationskuzzybucket has a superb reputationskuzzybucket has a superb reputation
No. The **** has a clip inside the plastic that holds it on the shaft, but it can be forced off
The switch is held in the dash with the nut you see when the **** comes off
nothing else is holding the switch in, except time, and gunk from it being there so long
You can push on the switch once the nut is off, and it should "break "loose
Then just push the thing through the hole with your finger, reach froom behind, and wiggle the whole mess down to where you can unhook the harness
ManI wish you lived nearby, I'd sure like to help, or at least provide morral support
Old 01-13-2018, 04:06 PM
arctic y block
We got it off but broke the grd wire off from it.
Now we cant find where the grd wire bolts in.
So i will find another grd. And put it all back together.
Update soon
Old 01-13-2018, 04:13 PM
skuzzybucket
It grounds outside the harness, and you have to look harder for it. I have broken almost every ground on every switch I ever removed from a 80-86
Glad you're making progress
Old 01-16-2018, 10:25 PM
McLeod's Avatar
McLeod
McLeod is offline
McLeod has a good reputation on FTE.McLeod has a good reputation on FTE.
skuzzybucket -
Your avatar freaks me out
Old 01-17-2018, 07:36 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
you think his avatar is bad???
you should be glad you never met the crazy bartstard in person!!!
Old 01-17-2018, 07:35 PM
skuzzybucket
PFFFFFFT
Your only mad because daddy caught you messin with my 400 lb sister in the sheep pen, and made you marry her.......
Old 01-18-2018, 05:33 PM
tjc transport
i ain't rite
you do not realize i traded her to Timmy down to Tennessee for a gallon of white lightning..........................18 years ago..............best trade i ever made. that heifer almost ate the damn house!!!
Old 01-18-2018, 05:45 PM
skuzzybucket
She'll be back..... She's like a bad penny..... A BIG one
Old 01-19-2018, 07:08 AM
tjc transport
i ain't rite
mehhh. she can try, but i moved far away after i packed her on the semi for the move. so she ain't gonna find me.
khadma
15
12-12-2011 09:29 PM
tbaker00
2009 - 2014 F150
10-01-2010 11:58 AM
MW95F250
General Automotive Discussion
15
03-15-2004 11:27 PM
Beachbumcook
02-03-2004 07:55 PM
Richard Tobin
07-30-2003 05:28 PM
Quick Reply: Help for a friend with a stroke
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
