Reading fuel pressure through Scangauge - Ford Truck Enthusiasts Forums
Modular V10 (6.8l)
Old 01-12-2018, 03:19 PM
NCMODELA
NCMODELA is offline
NCMODELA is starting off with a positive reputation.
Hi all I have a 2011 Ford e350 van 6.8 liter. Someone told me I could read the fuel pressure through the scan gauge II. I put in the appropriate x gauge codes but it still doesnít work. Is there anyone here that can verify that they can actually read the fuel pressure this way?
Old 01-12-2018, 09:53 PM
Hank85713
Hank85713 is offline
Hank85713 is gaining momentum as a positive member of FTE.Hank85713 is gaining momentum as a positive member of FTE.
contact SG direct, their tech line is very good. I dont know the answer, on my diesel I had to install a pressure gauge for it. The SG is used for monitoring the stuff the computer does. Voltage, trans temp etc.
Old 01-13-2018, 12:03 AM
NCMODELA
NCMODELA is offline
I contacted them and they gave me the x code for it. They said after I entered the code if it still didnít read that I couldnít see it. Thatís why I was asking if anyone with similar make or model actually could verify or have verified they could read it. Again I was told that it did have a sensor and should be able to read it. Trying to figure out if Iím doing something wrong
Old 01-13-2018, 08:10 PM
Mike189677's Avatar
Mike189677
Mike189677 is offline
Mike189677 has a very good reputation on FTE.Mike189677 has a very good reputation on FTE.Mike189677 has a very good reputation on FTE.Mike189677 has a very good reputation on FTE.
There is no sensor that reports the fuel pressure to the computer so you canít see it with the scangauge.
Old 01-13-2018, 08:22 PM
NCMODELA
NCMODELA is offline
Ok. Thank you
I was wondering because you can actually purchase one for the vehicle through rock auto
dr103
12-23-2011 11:57 PM
fixxxer-upper
12-13-2011 07:52 PM
sarnott140
03-29-2011 03:36 PM
WH90
11-28-2010 06:12 PM
hndacr
06-02-2010 09:31 AM
Quick Reply: Reading fuel pressure through Scangauge
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
