What do you have to remove to remove the PCV tube from the intake? - Ford Truck Enthusiasts Forums
Old 01-12-2018, 02:37 PM
1999-F150 1999-F150 is offline
1999-F150 is starting off with a positive reputation.
What do you have to remove to remove the PCV tube from the intake? I have felt around back there but I can't find it. Any help would be greatly appreciated.
1999 f150 5.4 4x4 auto
Old 01-13-2018, 08:09 AM
Rick NoLA Rick NoLA is offline
Rick NoLA is starting off with a positive reputation.
If it's like mine, it's a one-piece hose/fitting assembly. It's not a mechanical fitting. The larger rubber end is usually seems a bit stuck to the intake from heat. I use a wide-bladed screwdriver and my fingers and gently work around the edges of the fitting to pry/ease it off.
Rick
Old 01-13-2018, 01:40 PM
Quote:
Rick
Thanks Rick, I am just having a hard time finding it. I was wondering if the throttle body needed to be removed
Old 01-13-2018, 09:48 PM
Mine is on the back of the TB and pointed directly at the firewall. It angles upward a little.
Old 01-13-2018, 09:50 PM
The TB does not need to be removed. Both ends, the PCV and the TB are just tight rubber connections. The large end of hose goes over outlet on back of TB.
03 F150 4.2L V6 PCV Valve WITH PICTURES one4house 1997 - 2003 F150 18 12-04-2017 07:47 AM
Pcv question 1999-F150 1997 - 2003 F150 2 11-17-2017 09:30 AM
4V Intake Manifold Shadowrider123 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 16 09-09-2016 06:57 AM
PCV valve description steve(ill) 2004 - 2008 F150 3 02-23-2016 07:02 PM
Pulling my hair out rustybuttrusty 3.8 & 4.2L V6 0 02-02-2016 04:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
