Bad gas mileage - Page 2 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Bad gas mileage
Old 01-14-2018, 03:27 PM
rowdyredneck's Avatar
rowdyredneck rowdyredneck is offline
rowdyredneck has a good reputation on FTE.rowdyredneck has a good reputation on FTE.
I don't have a pressure gauge at home, I'll have to grab it at work tomorrow.
I'm flashing the codes. I don't remember if the scanner I have at work shows live data on these older EEC-IV systems or not...been a long time since I used it on something this old. Its a Snap-on MODIS.
I pulled the oxygen sensor back out so I could back probe both sides of the connector. It zeroed out on all three pins so the connection is not the problem. The sensor tip is black, so I pulled all of the plugs and checked them. They all look normal.
Old 01-14-2018, 03:35 PM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
I keep forgetting to ask how your scanning the computer & coming by the code numbers?
Old 01-14-2018, 04:10 PM
I'm connecting a jumper wire between the signal return and self test input pins. Turn the key on and it flashes the key on, engine off codes first followed by the continuous memory codes.
When the light first came on over a month ago I did use an old, obsolete MT2500 scanner at work and it showed code 41 at that time too.
Old 01-14-2018, 05:17 PM
I've been doing more research online. The oxygen sensor has three wires and as I understand one of them runs to a fuse link to supply power to the heater? I don't have any detailed wiring diagrams at home. Should this pin on the connector be hot all the time? Would an inoperative heater circuit cause this problem or would that just delay or prevent it from going into closed loop?
I should also add whenever the light comes on its almost always when I'm coasting or under light throttle. Usually happens right after I slow down to make a turn.
Old 01-14-2018, 08:19 PM
spooktn spooktn is offline
spooktn is gaining momentum as a positive member of FTE.
BBB Industries.com has a wiring help deal,,,just make a user name and password and your in,,,i looked up your truck and the hot wire to sensor is GY/Y,,,i assume this is grey with yellow strip,,,,should be hot with koeo and it is a low voltage,,,,i think 0.10 volts or less but will not swear to that voltage,,,,if you go to site just make sure to click it to wiring not TPS to see wiring diagrams,,,,i see pawpaw is now helping you out,,,,,he is very good with these old rangers
Old Yesterday, 11:58 AM
i still wont swear to the voltage but i think that voltage changes from 0.01 to 0.09 volts depending on rich or lean needs,,,,,but cant seem to find exact voltage anywhere yet
Old Yesterday, 12:28 PM
twigsV10's Avatar
twigsV10 twigsV10 is offline
twigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud of
I'm going to follow along, have the same issue on the same truck just an 89.
Old Yesterday, 08:07 PM
The verdict is in: it was the fuel pressure regulator. I took it in to work today and got there early so I connected my scan tool first but on these older EEC-IV systems I cannot view live data with it. With the Snap-on scanners you can't until about 1990 or 91 on Fords. So, I connected the fuel pressure gauge, turned the key on and the needle spiked at 105 psi!!! I started the engine and it held steady at 105. That regulator must have been completely blocked and wasn't letting any return fuel flow back. I called around but nobody had a new one in stock and the cheapest quote I found was $75, so I figured its worth trying a used one. During my lunch break I ran home and pulled one off one of my parts trucks and put it on tonight after work. Now I'm getting 43 psi KOEO and about 35 psi with the engine running. Big difference. I cleared the keep alive memory again and so far no check engine light. I won't know if my fuel economy improves for a few days yet but that had to be the problem. I'm surprised it would even run with the pressure that high, let alone run normally. I no doubt shortened the life of my in frame fuel pump.
I still don't understand why such high fuel pressure was causing a lean exhaust code. I would expect the exact opposite. I never suspected the regulator was restricted because the engine was running as smooth as ever and had absolutely no driveability issues.
Old Yesterday, 10:28 PM
Ok, good find & feedback on the fuel pressure check. Way to hang in there & not give up on your trouble shoot & to hear of the positive results.
Will be interesting to hear how fuel consumption checks, now that pressure is within proper range. Don't know that I've heard of pressure that high before. Bet the fuel injectors appreciate it being back in range.
Old Yesterday, 10:42 PM
hhhhmmmm wonder if running that rich could have hurt the cat,,,assuming a 88 has a cat,,,a can of cataclean would not hurt but it is kind of pricey at $29.95 or is it $19.95
Old Yesterday, 10:57 PM
Yes, it has a cat. Time will tell I guess. Both of my parts trucks still have good cats so I have backups in case this one does go south. I never saw any black smoke while it was running so I don't know how much unburned fuel was ever reaching the cat. I didn't notice any difference in how it ran after switching regulators either. Very odd that it ran as well as it did. I'm still completely stumped as to why it kept throwing a lean exhaust code.
Old Today, 12:00 AM
Quote:
Seeing as how you were reading the codes via a blinking CEL & the difference in a lean, or rich code is only one number, all you had to do was miss one blink!!!!
We don't know How rich it was likely running, but if you come to suspect a damaged cat converter you can perform a test with your vacuum gauge, by scrolling down & following test scenario 14 here Vacuum Gauge is an Invaluable Tool when Diagnosing Engine Problems
2000 f-150 5.4l p1151/p1131 p0174/p0171 kf7dwc 1997 - 2003 F150 5 12-28-2017 03:31 PM
If you can solve this you are a real pro JeffHWV Modular V8 (4.6L, 5.4L) 32 12-05-2017 02:03 PM
Code P0153 P0133 2000 Ranger just report it as stolen? rogerranger2122 Ranger & B-Series 23 08-08-2016 07:24 PM
Cold running issue after MAF swap '90-f150-302-5spd 1987 - 1996 F150 & Larger F-Series Trucks 24 06-01-2016 01:51 PM
Help Needed: Engine Idle & Misfire Issues neal2ross 1987 - 1996 F150 & Larger F-Series Trucks 16 04-06-2016 09:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
