ROTATIONAL CLICKING IN FRONT END TURNS INTO MAJOR SURGERY
on
thanks for the comments...definitely not a tire/gravel issue as we just did a rotation.
The sound reminded me of when we were kids and used a clothes pin to hold a baseball card on a bicycle wheel to make it sound like a motorcycle. Flap flap noise that increases with speed, with or without brakes or 4x4 in use.
It started after using cruise control in the steep mountains in Pennsylvania. When going downhill, the cruise makes the vehicle slow down by gearing down. Coincidence or could this have caused my issue? Any opinions on using cruise control on steep hills vs braking for long periods going downhill? Is this ok or did this f-up my truck?
I like the thinking there, but there might be a issue there. Since all 4 wheels would be off of the ground, there would be no load on the engine or rest of the drive train. In most cases with dealing with differential and other like components, they can act very differently with load and without. I hope that made sense...havent had my coffee yet.
On the other hand, if its not under warranty, anything that you can do to narrow the problem down will save you money in the end. Since I doubt any shop would allow you to do this (insurance issues!) you'll have to try this in your driveway - get the truck up on 4 jack stands. Fire it up in 4-High and have someone sit in the truck. Give it a LITTLE gas and ride the brakes to load the drive-train. If you're hearing the noise while just cruising down the street, you really don't need a lot of load on the drive-train to make it click. If it is a problem in the braking system it should make the noise before you ever touch the brake pedal.
I don't know of any shop with a 4 wheel dyno that will run your truck for cheap.
Hard to say what the reason is. I'll tell you that I've had vehicles that have never had a bearing failure, and I've had a couple that have had one or two. To some extent it's dependent on the skill of the technician.
#29
