power bucket seat wiring
on
verified that my seats work forward,backward, up and down... but haven't messed with heaters
these diagrams lead me to believe that if power is applied to the main seat lines that I also have power to the heater circuits... that look right to yall ??? I hate car wiring diagrams like this
Received 4,130 Likes
on
There are other components in the vehicle they came from John and I really don't think you need the heat function to work where you are. When I had my seats reupholstered I eliminated the heating pads and the memory functions .Just used the main power and ground wire , tied them together on one circuit. There isn't enough room in the cab to get the full function of the seats anyway..
on
Bob, I've got a better set of diagrams and more pages... I just don't know all the nomenclature and legends... must have missed that page. figured S= switch C= connector, etc but the symbols I don't know..
mainly wanted to know if the seat heat module got power from the main seat motor wiring... guess I need to get in there with a volt meter and follow some wires, eh ?? I can scan the other pics and send if you want to see them... let me know
John,
That looks like a GM wiring schematic. Yea, not my favorite style of schematic either but what can you do.
I would say that yes, the seat heater get their power from the main switch which is getting its power through the circuit breaker and the fuse. I'm guessing that the 40Amp fuse is one of those Maxi fuses.
Bobby
Bobby
on
John,
Bobby
Bobby
I recently got the electronics controls for my bucket seats wrung out and operational...what a PITA, and I am an electrical engineer. I am using the seats out of a 2004 Lincoln Aviator which had all the fancy Driver1/Driver2 memory crap in it. All of the controls for the memory including mirror adjustment, seat location, steering wheel height, etc., etc. is located in the driver's seat. I ended up buying another passenger seat and swapped the electronics into my drivers seat to simplify the circuitry. As for the seat heaters...my seats have a separate power source and a separate control switch for the heaters. My seats have the controls located in the doors rather than in the base of the seat so the wiring is a bit more complex. I took all the pertinent wiring pages out of the Lincoln service manual and I pieced it all together so that I will have a good reference document to go with the vehicle. I also drew up a schematic that has all the circuits on one page...there is a lot of other stuff on those drawings that are only a confusion factor. I would take the info that you have circled in your green square and draw a schematic from it using what is really in your truck...it will make it a lot easier to wring out.
Well, I'll be....
Learn something new everyday. I've been out of the game for awhile, I didn't realize that the other manufacturers went to that style of wiring schematic.
Back when I was wrenching I hated those schematics when they first came out. It's like everything else though, if you use them often enough they aren't too bad.
Bobby
on
on
