Choke cable adapter
Choke cable adapter
Would anyone have advice on an adapter to connect the choke cable to the carb ball link? I replaced the carb and the linkage is different. Do I need to manufacture my own? It doesn't look like I can swap the linkage. You should see the blank stare when I try to tell the young guys at the parts store what I need.
It is a 226, I believe. I guess I should find some numbers to confirm but I believe it's the original and the spec sheets that I've found say 226. I could manufacture a link, I think, but I'd prefer to have something that doesn't make a person scratch their head and make comments about rednecks.
I think your "original" carb must be off a much older truck, or another brand even, I don't recognize it. The choke lever on the new one is very similar to the ones used on Holley 94's, I think trying one of those is your best bet. At most you might have to splice the lower part onto the new carb's lever, should be pretty easy if you can weld.
Maybe someone on here will step up with a spare?
Part of your troubles is that your carb appears to be a car carb, not a truck carb, and they may have different linkage setups. It also explains why you haven't had a response to your air cleaner question as we're not familiar with the car air cleaner. Maybe researching 49-51 car choke linkage will help in your quest.
You should be using a 7HT carburetor for your F5 with the 226, not an 8HA or Autolite 1100. Otherwise, as stated before in this and other threads, you will have to overcome/fabricate around the differences in linkages, air filter housings, fittings etc. all of which may not be trivial, especially since an Autolite 1100 was already shoved in there.
The following users liked this post:
Iszy131
12-18-2021 06:47 PM
Yogi-96blazer
03-02-2006 07:37 PM
GregTruck
05-17-2005 11:43 AM
TheBondoBandit
01-30-2004 07:04 PM
