Another Front Shock Question On 1949 - Ford Truck Enthusiasts Forums
Old 01-12-2018, 06:31 AM
1949f1's Avatar
1949f1
1949f1 is offline
1949f1 has a great reputation on FTE.1949f1 has a great reputation on FTE.1949f1 has a great reputation on FTE.1949f1 has a great reputation on FTE.
I have searched this through all the post and what I have found out is the front is 17.73 extended 11.12 collapsed 6.61 stroke.
I have had my stock springs rebuilt and with the engine in and no front end on the truck I have 17 3/4 center to center on the shock mounts. I have the stock straight axle.
I know that when the complete dog house is on it will drop down some but not much because you can barely compress the suspension any. I also know you need to have about three inch's of travel for the shock. Any one run the rear shocks on the front because they would work out with the travel needed. Some 53 thru 55 run the same all around. Thanks
Old 01-12-2018, 12:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Same situation for mine, so I went with these: Gabriel 77405 MAX CONTROL
12-1/4" collapsed, 19-7/8" extended. In the pic the red shock is a Monroe/Gabriel that is extended, the Max Control is still tethered. You can see the difference in diameter tho. Nice boot too.
Old 01-12-2018, 12:33 PM
1949f1's Avatar
1949f1
1949f1 is offline
Thank You. This helps me out a lot. I will look into them.
GLR
12-14-2013 07:02 AM
Growl60
06-19-2010 03:26 AM
yamaman22
07-22-2007 03:01 PM
dennylm
Fifth Wheel & Gooseneck RV Towing
12-26-2006 08:40 AM
loghomeman
1999 to 2016 Super Duty
01-09-2005 08:28 PM
Quick Reply: Another Front Shock Question On 1949
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
