55 F100 Y block - Ford Truck Enthusiasts Forums
55 F100 Y block
Old 01-12-2018, 04:55 AM
BGF100 BGF100 is offline
BGF100 is starting off with a positive reputation.
55 F100 Y block
Hi,
whats the best method to clean the contact surfaces for the cylinder head gasket?
Thanks,
Old 01-12-2018, 05:36 AM
seaves46 seaves46 is online now
seaves46 has a good reputation on FTE.seaves46 has a good reputation on FTE.
Razor blade or other sharp type of scraper .
Then a good clean with some type of cleaner , I usually clean with paint thinners .
Old 01-12-2018, 02:36 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.
When you have the surfaces all nice and clean and start to assemble, make certain you have the head gaskets installed correctly. The consensus is that the original steel gaskets are to be avoided in favor of the composition gaskets.
Old 01-13-2018, 12:06 AM
jcslocum jcslocum is offline
jcslocum is starting off with a positive reputation.
Quote:
Originally Posted by BGF100 View Post
Hi,
Thanks,
3M Scotchbite bristle rotary brushed. I use the white ones to do headgaskets.
Old 01-13-2018, 09:57 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Scotch brite shouldn't be used, the particles it sheds are abrasive.
https://www.bobistheoilguy.com/forum...&Number=563163
f-100 401tonyo 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 03-27-2017 10:31 PM
f100,s at gnrs bzerk56 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 02-05-2017 03:52 AM
f-100 C-700 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 01-26-2017 10:50 PM
74 F100 Doomcrew2123 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-17-2016 10:21 AM
F100 usmcdad 1961 - 1966 F-100 & Larger F-Series Trucks 0 04-14-2016 02:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
