Truck wont start... - Ford Truck Enthusiasts Forums
Truck wont start...
Old 01-11-2018, 06:04 PM
F151's Avatar
F151
F151 is offline
F151 is starting off with a positive reputation.
Truck wont start...
I had my starter rebuilt, installed new cables, and a new starter solenoid/relay. The solenoid/relay I have since returned to autozone because it didn't work. I installed the old solenoid and there was movement but not enough to turn the starter. I've tried touching the starter cable to the other post on the solenoid/relay and there was spark and i some turning in the starter but still no dice. I rocked the truck back and forth in 3rd gear and that didn't work as well. I had the battery tested and charged, everything is fine with it. Is it worth ordering a new solenoid? Is the ground bad? any suggestions? I can't figure it out.
Old 01-11-2018, 06:53 PM
3twinridges's Avatar
3twinridges
3twinridges is online now
3twinridges has a great reputation on FTE.3twinridges has a great reputation on FTE.3twinridges has a great reputation on FTE.3twinridges has a great reputation on FTE.3twinridges has a great reputation on FTE.
Are you 6v positive ground and if so what size cables are you using?
JB
Old 01-11-2018, 07:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Does your old solenoid/relay have a button on the bottom of it? If so, push that up, that manually closes the contacts.
Is your starter button a 1-terminal or 2-terminal type? There was a change in late '51 to the 2-button type, which sends power to the solenoid. The older style (1-terminal) grounded to the dash, and if there is a bad connection there to the dash, it won't work right.
Old 01-11-2018, 09:40 PM
F151's Avatar
F151
F151 is offline
JB
Yes, it is 6v positive ground. I'm using 4 gauge I believe.
Old 01-11-2018, 09:42 PM
F151's Avatar
F151
F151 is offline
It's a one terminal type. I cleaned the connections but I may have missed some. I'll double check.
abe's Avatar
abe
abe is online now
abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.
There you go. You gotta use 0 gauge or 00 gauge for 6 volt. And make sure your contact points are clean and rust and paint free as well as your ground connections.
Old 01-11-2018, 10:08 PM
3twinridges
If I had the same problem as you, I first would put heavier cables on it, find either a correct Nos or used solenoid, clean all connections, and use bulb grease on them to keep them clean. Then crank it while watching the solenoid connections. If they turn red hot you don't have them tight enough. If you still have problems move to the starter for continued troubleshooting.
Like Ross said, if you are using the earlier style push start run a piece of sandpaper in the hole to expose bare metal on the edge, add a little bulb grease, and reinstall. Do all of that with the battery disconnected as you can actually trigger the starter doing that and if the truck is in gear it will lurch forward, ask me how I know.
JB
Old 01-11-2018, 10:18 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Smaller cables wouldn't prevent it from cranking completely.
Old 01-12-2018, 05:33 AM
big job's Avatar
big job
big job is offline
big job has a great reputation on FTE.big job has a great reputation on FTE.big job has a great reputation on FTE.big job has a great reputation on FTE.big job has a great reputation on FTE.
6vt pos gr. 1948 to 50 I presume. It is most important that the solonoid and the starter
button on dash has a good ground. Next the cab must have a good ground to engine.
Just went through that we forgot to hook up the cab ground that causes all kinds of
funky things as they will seek a ground through speedo. cables ebrakes etc. In time
solonoid internal copper washer gets "spark corroded" dirty. If all thats good I would
check starting amps there are ampmeters that are held on the starter cable for that
they are cheap nice to have in your box. You rock the truck and nothing. Two things
the good ;- something wrong with the starter the bad; ring gear came off. Just been there
with that. Went to store and thats all she wrote click click got towed. Took jammed
starter out yep ring gear against block. Luckey we banged it back and migged 4
equal dots on gear flywheel. Thats a design flaw the flywheel shoulder should be toward
the block and not toward the clutch. How in hell did that happen? I had no noise
engine at idle shut it off and then a tow?? no warning at all.....
Old 01-12-2018, 08:29 AM
firstrider's Avatar
firstrider
firstrider is offline
firstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to behold
What Abe said !!!!
Old 01-12-2018, 08:57 AM
49f3dls's Avatar
49f3dls
49f3dls is offline
49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of
My F3 required better swear words! ��
Old 01-12-2018, 10:14 AM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
petemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud of
Knowing what year, model and engine would help. Pictures are also essential otherwise we will be guessing.
Old 01-12-2018, 12:30 PM
dennisb56's Avatar
dennisb56
dennisb56 is offline
dennisb56 is gaining momentum as a positive member of FTE.dennisb56 is gaining momentum as a positive member of FTE.
Tractor Supply usually has heavy gauge cables for 6 volts systems.
Old 01-12-2018, 12:39 PM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is online now
Kentucky Chapter Member
EffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant future
I have some questions,
1) Was your truck starting before you updated the starting system?
2) Is the battery cable grounded directly to the engine?
If not:
2a) Is the engine grounded to the chassis with a cable equal to the battery cables?
If so:
2b) Is the engine grounded to the chassis with a heavy wire, not necessarily as heavy as the battery cable?
3) Is the cab grounded to the chassis/engine with a heavy wire, not necessarily as heavy as the battery cable? (Big Job hit on this)
4) Have you tried directly grounding the "start" post on the solenoid to the engine/chassis/battery?
Old 01-12-2018, 01:47 PM
F151's Avatar
F151
F151 is offline
I will post some pictures later this afternoon when I can take some. The truck is 1951 F1, V8, 239ci, positive ground, 6v system.
Quick Reply: Truck wont start...
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
