2020 SD Videos that Dropped Today
OP, thanks for the one stop shop for new vids! Plenty of content to view today.
Agreed. Their high altitude MPG might be comparable to my low elevation and heavy foot. I need more truck and would prefer a stronger gasser than what I got. It might not have the MPG of some other vehicles but it should do well for everything else.
@Louisville Joe I don't remember the exact number but the new 7.3 and 10 speed is only like 80-90 lbs heavier than the 6.2 and 6 speed. They are using the same springs on both engine setups.
There's some decent info in the new videos, although most were underwhelming. Some disinformation too, even from the Ford techs. One video with Mr Truck they said they didn't lower F450s or F350 4x4. And then in another they said they lowered F250s and F350s. And that one tech that rambled about chips was full of it. If they could get more MPG and power they would. Um ok, so in a few years it won't get a boost in numbers? And that soft fly by wire pedal is better how? Another tech from an older video said they were conservative with the new motor so the can play it safe and then reassess where to go from there after it's proven.
@Louisville Joe I don't remember the exact number but the new 7.3 and 10 speed is only like 80-90 lbs heavier than the 6.2 and 6 speed. They are using the same springs on both engine setups.......
Interesting, and I will bet a lot of that slight extra weight is the 10 speed transmission.
