Timken Hub Assembly morning - Ford Truck Enthusiasts Forums
Old 01-11-2018, 07:53 AM
Old51f3's Avatar
Old51f3
Old51f3 is offline
Old51f3 is gaining momentum as a positive member of FTE.
Im trying to remove the drum mounting plate to get an exact size from my axle flange to the Hub mounting surface. to do so I see I have to take My Hub apart. Is there an easier way. ?
Old 01-11-2018, 10:07 AM
moejr
moejr is offline
moejr is gaining momentum as a positive member of FTE.
Google Ford axle flange bolt pattern
Old 01-11-2018, 02:10 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Caption below pic: Timken model 51524 / Models: D = F2 / Y = F3 / J = F3 Parcel Delivery / JH = F5 Parcel Delivery / T = F5 / TL = F4 / W = F5 COE
Old 01-11-2018, 05:38 PM
itsnotavan
itsnotavan is offline
itsnotavan is starting off with a positive reputation.
with those 8 axle nuts on a few threads, give the axle shaft a good whack with a brass hammer at a right angle to the shaft. That should free up the 8 cones under the nuts and then slide the axle out. If you try to free them off with out the nuts on a few threads chances are better than not that one will shoot off to a unknown crevice in your garage.
now that the shaft is out, free off the locking tab from the lock nut and remove as normal, keeping a note or picture of the parts stack.
grab the stub hub and pull straight out and now you have access to the backing plate mounting bolts.
here are some Pn's for your parts guy
bearing/race inner, Timken 18690/18620
bearing/race outter, Tinken 18790/18720
grease seal stub hub, SKF 23820
grease seal pinion SKF 13738
Old 01-12-2018, 12:12 AM
Old51f3's Avatar
Old51f3
Old51f3 is offline
Thank you so much. Came out like a dream ..
chefcollins1
1999 to 2016 Super Duty
07-14-2014 06:05 AM
Macmathews
26
03-25-2014 03:27 AM
dakido
19
10-02-2011 11:26 PM
HD RULES
08-30-2011 02:19 PM
brucear777
1997 - 2003 F150
05-21-2010 09:35 PM
Quick Reply: Timken Hub Assembly morning
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
