79 Crew Cab :R&D turbo kit(sink included) - Ford Truck Enthusiasts Forums
Old 01-10-2018, 09:16 PM
uniwagon uniwagon is offline
uniwagon is gaining momentum as a positive member of FTE.
Hello I have looked and found not what I was looking for so here it goes. Has anybody on here installed a complete turbo kit from R&D.I am talking Turbo,manifolds,intake,intercooler,pump,studs..... .ect.I have talked on the phone with him at length about how to get the same performance out of the 7.3 as the 460 I have now and then shut the hood and only open it to change the oil.
I am committed to the idi(cummins will not fit due to the twin transmissions I have) Swapping into a 79F350 Crew cab,so I need the turbo and all of the fixins to build it once.I am sold on the performance that I will get but has anybody else thrown the kitchen sink at one of these things???
Chris
Old 01-11-2018, 11:04 PM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
I sure as heck don't have the money for such a kit, but I've done a few mods. I have no doubt that all of the R&D products work as expected, it's good stuff.
I've seen him make 400+HP at the wheels with an IDI, so I know he can do it.
Personally, well, you can see my sig. I'm at easily 35% more than a stock 460 V8(easily double a stock IDI), with a stock engine, factory turbo and just a RD2-110 and adjustments to use it.
Old 01-12-2018, 10:57 AM
Hello again.I just am looking for actual street driven feed back on the parts before I go head first.I have the utmost confidence in Justin and his parts but I am replacing a 450hp ish,550 ftlbs ish 466 that is perfect the way it is.
But I am moving to the west coast and to be able to keep the truck(tows my race car)I have to install a diesel To exempt it from emissions.
I know I am asking a lot from a 30 year old diesel unless someone out there has a 73-75 F350 with a 167 wheelbase with a title that I could "barrow" This is the only way forward.
Chris
Old 01-12-2018, 12:30 PM
cadunkle's Avatar
cadunkle cadunkle is offline
cadunkle has a good reputation on FTE.cadunkle has a good reputation on FTE.
I feel your pain. I have a 460 truck with similar power output that was originally a 351w. Eventually I ran out of palces to buy stickers so ended up buying an IDI truck and it has been a long road just to get marginally acceptable performance out of it for towing, still a long way to go before I would consider it the same or better than my 460 truck that just sits and rusts now.
Old 01-12-2018, 01:04 PM
Chevy_Eater's Avatar
Chevy_Eater Chevy_Eater is offline
Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.
Chris
If by the west coast you mean California then you're not going to get a '79 exempt with a diesel.
Old 01-12-2018, 07:45 PM
Macrobb's Avatar
With a carburated gasser, how hard is it to just install a catalytic converter and clean up the exhaust?
Sounds like you'd probably just have to slap a catalytic converter and probably an air pump on there and see how it works. As long as your mixture is close-ish, it should work?
Old 01-12-2018, 08:31 PM
We still don't know if he's talking about Commiefornia or not, but they more than just emission test here, they visual test to make sure everything is bone stock.
Your emissions could be zero, but if you're missing a part or do not have "California" certified cats you fail big.
Old 01-12-2018, 09:15 PM
Hello,Yes California,yes I have read all of the laws and talked at length with people who have done this legally and proper.I also called a CA dmv and talked with them.
You can only install a newer diesel in a smogged truck that was available in the same weight class or one lower 3/4 or 1 ton that was in from the factory truck of the same size.All diesel pick ups up to 97 are exempt. because they don't have any emissions equipment to start with.
You can retro fit a newer diesel (1988 7.3idi with proof of what it came out of ,I have the wreaking yard receipt for the engine) in to a older truck 79 F350,go to the dmv and ask for a change of registration to a diesel engine they inspect to prove that you installed a diesel then change the vin ending with a "d" and send you a new title with the updated vin with your registration.
You can't install a engine older than the vehicle or that was never offered in it IE.......no Dt466 or 6v53s
Old 01-12-2018, 09:20 PM
Macrobb's Avatar
I hate to say this... but why would *anyone* want to go to commiefornia?
Old 01-12-2018, 09:22 PM
P.S. My F350 is originally a non converter truck factory and started life with a 300 6. and the 460 in now came out of a 69 Lincoln.So no amount of emissions trickory is going to make it pass,diesel swap is only way forward.Like I said unless one of you has a 73-75 f350 with a 167 in wheelbase and a good title.
Chris
Old 01-12-2018, 09:24 PM
Quote:
Because I have lived in NE PA for my whole life and hate it and SNOW.
Old 01-12-2018, 09:27 PM
Macrobb's Avatar
Well how about Nevada, Utah, Arizona, or even Oregon or Southern Idaho? Or just about anywhere *but* california?
Old 01-12-2018, 09:52 PM
DrCharles DrCharles is offline
DrCharles is starting off with a positive reputation.
Wildfires, mudslides, earthquakes, 2 hrs to drive 10 miles, and smog is SO much more fun?
Old 01-12-2018, 10:11 PM
Quote:
Actually I am looking at in or around San Diego, no fires or mudslides.
If you read all of the emissions laws in all of the states of the southwest ,Cal. is actually the easiest to deal with.Arizona,Nevada ect..... all test back to 1967 in the areas where most of the people live or that I would want to live.Besides I am a drag racer and a hotrodder and SC all of that is year round.
Turbo set ups any one?
Old 01-13-2018, 11:49 AM
mroth2008 mroth2008 is offline
mroth2008 is gaining momentum as a positive member of FTE.
I havent heard one complaint, and honestly even modified stock system like mine will eat a 460 for breakfast. 500$ s366 100$ intercooler 100$ in piping. Make a factory idi a good tow rig, Im starting to tweak my timing on my truck. The only change I would do on mine is a smaller turbine housing. Mac on here went from 091 housing to a 063 and he loves it spools faster.
74 or 79 crew cab ?? Ford Road 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-31-2017 10:37 AM
Sink Not Draining Jeff64F100CrewCab Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups 7 06-20-2017 11:40 PM
Best power upgrades for 1997 F350 Dually 4x4 5-Speed? Brian Donoghue 1987 - 1996 F150 & Larger F-Series Trucks 1 04-20-2017 07:28 PM
F-350 problems PNW350SD 1999 - 2003 7.3L Power Stroke Diesel 44 09-21-2016 02:18 PM
Engine surging in hot weather, loss of engine power, engine backfires, no start THE BLUE HEAP 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 07-01-2016 12:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
