Look at this Cab Chassis front axle. What is going on? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-10-2018, 02:12 PM
2000F2504X4 2000F2504X4 is offline
2000F2504X4 is starting off with a positive reputation.
This is a 2006 F350 cab chassis. Why does the front axle look like an axle from a SRW truck? Any ideas?
2006 F350 Cab Chassis
Old 01-10-2018, 02:15 PM
yardbird's Avatar
yardbird yardbird is offline
yardbird is starting off with a positive reputation.
It looks to me like someone put F250 rims on an F350.
Old 01-10-2018, 02:20 PM
I was thinking that too, but normally the 4x4 hub is recessed into a dually wheel. I am thinking that this is an axle swap from a SRW truck, or there are some spacers/adapters missing. Hoping someone here knows.
Thanks,
Old 01-10-2018, 02:23 PM
brandon_oma#692's Avatar
brandon_oma#692 brandon_oma#692 is online now
brandon_oma#692 has a good reputation on FTE.brandon_oma#692 has a good reputation on FTE.brandon_oma#692 has a good reputation on FTE.
Someone removed the dually adapters.
Old 01-10-2018, 02:27 PM
You think it is as simple as that Brandon? Are F350 front axles the same for dually/SRW except for the OEM adapters?
Old 01-10-2018, 02:43 PM
I found some pictures.
Is the hub adapter on the front the only difference between a SRW and DRW?
Old 01-10-2018, 02:45 PM
Quote:
not 100% but think so I should have said. It could very well be a srw front axle swapped in or a srw chassis cab truck with a rear drw axle swapped.
I know on mine (leaf spring) many parts swap between the 4x4 srw front, 4x4 drw front, and the monobeam front axles. Ignoring early 99. I could take my dually adapters off and run a srw wheel as long as it cleared the brakes. I'm keeping my eyes open for a 4x4 front axle for a possible future swap.
Old 01-10-2018, 02:46 PM
DRW might have larger brake rotors and calipers. My 450 ones are bigger than my old 250 but not sure on the 350 drw
Old 01-11-2018, 12:29 AM
Copper.Farm's Avatar
Copper.Farm Copper.Farm is online now
Copper.Farm is gaining momentum as a positive member of FTE.Copper.Farm is gaining momentum as a positive member of FTE.
F250 and F350 have the same rotors and calipers, F450 are massively different.
Cab and Chassis Dana 60 question GNR22 1987 - 1996 F150 & Larger F-Series Trucks 2 10-01-2017 11:28 AM
New from Scottsdale, AZ Laggy New Member Introductions 1 05-16-2017 10:32 AM
Winnebago F17 1967 On F-350 Chassis MotorCityBolt 1967 - 1972 F-100 & Larger F-Series Trucks 5 05-05-2017 09:49 PM
1978 F250 4x4 longbed chassis Dana axles Judolizard Ford Truck Parts for Sale 1 03-10-2016 02:55 PM
Need info on F450/550 4x4 C&C axles... Phy 1999 to 2016 Super Duty 9 03-02-2016 12:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
