No communication with ECU 7.3l
Old 01-09-2018, 01:05 PM
Tillsonwelding's Avatar
Tillsonwelding
Tillsonwelding is offline
Have a no start condition with 01 excursion 7.3 l. Tried to watch datastream for icp pressure and can't communicate with ECU . Have communicated previously last week when working on it and got p1294 code and p1280 code
Old 01-09-2018, 08:32 PM
cookie88's Avatar
cookie88
cookie88 is offline
Welcome to FTE! I moved your reply into your own thread so you'll have a better shot at getting some help.
Old 01-10-2018, 04:51 PM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is offline
It's a Van Gogh
Check the fuses. The ECU aka PCM is powered by a fuse that also feeds the fuel bowl heater. If the heater shorts and blows the fuse the PCM will not work. Same fuse powers cigar lighter too IIRC. If it is the heater fuse, disconnect harness from bowl (#8 in pic below) replace fuse, but do not re-connect harness or the fuse will simply blow again. Some people in warmer climes leave it disconnected.
Seem to recall the DLC aka OBDII port also has a fuse that can prevent communication, but that won't cause a no start.
File Type: pdf
Old 01-13-2018, 05:52 PM
Tillsonwelding
Ok I bought an OBD2 breakout box to test the dlc connector values. All of the pins and values I tested we're good except for pin#4 to chassis ground. There was .9v of resistance. Not sure where to look for this problem. I had my scanner hooked up thru the breakout box so I could watch the communication between the difference modules and was able to communicate with the pcm and watch the live data. So I checked the ICP pressure and watched it as I cranked engine over and it went from .26v to 2.95v while cranking. Also noticed cranking voltage dropped to 8.7v which won't allow idm to fire injectors. Also got a p1670 code. Going to put new batteries in and see what happens . I thinking the idm is bad or could be relay for Idm. Going to test/replace relay as needed and go from there. Any thoughts?
Old 01-13-2018, 09:32 PM
hydro man 17's Avatar
hydro man 17
hydro man 17 is offline
I would wait until the new batteries are installed before doing any more digging or part purchases. 8.7 VDC is well below the minimum threshold (10.5 volts) to get anything to behave properly.
Old 03-05-2018, 01:47 PM
Tillsonwelding
Ok got new batteries in and tested cranking voltage and was in parameters to operate idm. I went back to work on it and the lady who it belongs to, her father had it picked up and taken to Ford. So they told her it was all 8 injectors and it ran. I went and picked it up and it wouldn't run and had to have it towed. Obviously there's more of an issue. I put my scanner on it again and have no communication with ECU again
Old 03-05-2018, 01:57 PM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
They replaced the injectors? That's like $1500 plus labor if I am not mistaken.
Old 03-05-2018, 04:20 PM
Tillsonwelding
Yea the dealership wanted $4770 to do injectors. I had it picked up bc I don't think that's the issue. Was just checking with another scanner I have and found a code for pcm short to ground. Code is U2016
Old 03-05-2018, 04:24 PM
Tillsonwelding
Also have code for injector circuit high bank 2 p1294
Old 03-06-2018, 07:16 AM
Tugly's Avatar
Tugly
Tugly is offline
Eventually, you'll need to pop at least one valve cover because you have a bad UVCH.
Our protocol is J1850 PWM, so we use a pin on the OBDII port that almost no other vehicle does. I think it's the pin 2 Battery volts. A weak ground is no good, I'd go on safari for that one and fix it. If they say it runs, was the mechanic the one that failed to get it started when you went to pick it up? If not, maybe they just pulled the ICP sensor plug to get it going in the shop.
Old 03-06-2018, 07:31 AM
Tillsonwelding
I tried unplugging the ICP sensor as well to get it started when I first started working on it and it won't start. What ground should I look for to fix?. I will order the valve cover gaskets and the uvch for the injectors as well. I also found some chewed wires by the pcm plug in the driver's side fenderwell so in the process of pulling out the harness and going to take it apart and check for other damage and or corrosion
Old 03-06-2018, 10:08 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
The Injector Drive Module (IDM) is located there, just FYI.
Stewart
Old 03-07-2018, 11:54 AM
HD Rider's Avatar
HD Rider
HD Rider is offline
Someone last summer chased a similar issue. The problem turned out to be a shorted EBP sensor. His ECM could not communicate because of low reference voltage.
GRECO
11-17-2018 11:12 AM
stonemason
08-02-2013 09:58 PM
jdcunn99
03-16-2013 10:32 AM
StillNotKing
02-20-2011 07:43 PM
bdub2
02-11-2004 09:03 AM
Quick Reply: No communication with ECU 7.3l
