96 ford ranger manual transmission 4 cylinder engine replacing the dmte - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Reload this Page >
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-09-2018, 02:15 PM
taxiridefun
taxiridefun is offline
taxiridefun is starting off with a positive reputation.
the position placement of the new part(where you attach the vacuum lines) is different than the original. how does one make the vacuum hose lines fit? they don't fit. why does ford change designs on parts that makes it so hard? any help would be appreciated. I would post photos but do not see a photo option.
Old 01-09-2018, 05:57 PM
ranger pat's Avatar
ranger pat
ranger pat is offline
ranger pat has a very good reputation on FTE.ranger pat has a very good reputation on FTE.ranger pat has a very good reputation on FTE.
You would probably get faster responses if you spelled out what dmte stands for. Lots of parts are called different names by different people and even in different parts of the country.
Old 01-09-2018, 06:24 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Could that be the DPFE EGR sensor you are talking about? It is entirely possible you got the wrong part from the store too, those guys generally don't know anything except what comes up on their screen, and everything that comes up on their screens was input by somebody else that knows absolutely nothing about cars.
Old 01-09-2018, 06:25 PM
Kruse
Kruse is offline
Kruse is gaining momentum as a positive member of FTE.
Are you talking about the DPFE (at least, that's what I call it) sensor?
(EGR pressure feedback sensor?)
Old 01-18-2018, 04:02 AM
taxiridefun
yes. Here's the whole situation 96 Ford Ranger manual transmission 4 cylinder engine with 197,000 miles on the engine so the check engine light comes on so I have the codes and it said it was the DPFE sensor and that there was a blockage so I watched Schrader's videos on YouTube about the whole vacuum system right and he described symptoms when you put gas in it there's a document there there's no place for the gas for the vacuum to go and so it'll shut the gas nozzle off when you're pumping gas and then all of that had been occurring in my vehicle and since I had a hundred and ninety-seven thousand miles I bought the truck used I figured well it's time to replace some of the stuff so I replaced that but the one the Ford sells the placement was different so I trace the numbers on the one that was on my truck and the Ford dealer said that came back associated with the Ford Cougar so I bought I thought the D then my check engine light came on again but I was able to finally put gas in without the gas nozzle shutting off and gas spurting out but the check engine light came on again ran the codes it still said there was a blockage and that it could be you know any one of those things that that it was possibly the EGR solenoid so to make a long story short I replace the EGR solenoid the DTM me whatever it's called and the EGR valve sensor in order to take the EGR valve off cuz the wrench couldn't get in there and I just cleaned the gasket off and reused it and lo and behold but I did clean all of that out I cleaned the pipes out I cleaned you know I got a new air filter I clean the intake out my friend looked at the intake looked at everything I cleaned he said yeah it looks great now. The check engine light came on and it says it's the EGR valves that I just replaced and now I'm right back where I started the gas nozzle shuts off and gas spurts out when I put gas in my truck I'm just right back where I started I replaced all my vacuum hoses cleaned everything behind the EGR valve cleaned all that stuff out the only thing I haven't replaced is that sensor that I had to remove to get the wrench in there to get the EGR valve off the back pipe so what the heck is it I got a new gasket for that sensor that I had to remove to get the wrench in there to remove the EGR valve from the back pipe but I haven't put it on yet so what else could it be I'm right back where I started and it says it's the EGR valve and I just replaced the flipping thing and I clean the pipe behind it and I clean the two pipes that the DTM e whatever it's called connect to and put new the special valve hoses on that I've replaced everything except that one sensor and the charcoal canister! any ideas. I mean I've got to get my emissions done by the end of the month and I'm no closer to solving the problem no closer any ideas
oh yeah I forgot to mention. gas cap? yep brand new. been there, done that !lol!
the idle air control valve is what I had to remove to get wrench in to remove erg valve.
I have new gasket have not put it on, have not replaced this valve.
Last edited by taxiridefun; 01-18-2018 at 05:34 AM. Reason: forgot to mention gas cap
Old 01-18-2018, 10:36 AM
KF4EYR
KF4EYR is offline
KF4EYR is starting off with a positive reputation.
have you tried unhooking the battery and rehooking it after about a 20 minute wait? sometimes the system just needs a serious rebooting,,,,
Old 01-18-2018, 11:16 AM
taxiridefun
well the battery was disconnected for several hours each time I worked. on these. the computer has to reset now but the check engine light comes back on.
xjcamaro89
2004 - 2008 F150
432
07-19-2018 11:22 PM
awq134
2009 - 2014 F150
23
05-05-2018 04:39 PM
1998Ranger25L153CID
Ranger & B-Series
11-03-2017 04:58 PM
Tedster9
02-19-2017 08:25 PM
cupchurch
1999 to 2016 Super Duty
08-06-2016 12:24 PM
Quick Reply: 96 ford ranger manual transmission 4 cylinder engine replacing the dmte
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
