89 Ranger turn signals inop - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-09-2018, 10:12 AM
OleskoolCarl's Avatar
OleskoolCarl OleskoolCarl is offline
OleskoolCarl is starting off with a positive reputation.
Good day everyone Iíve got a 89 Ranger That I have no turn signals but I do have Flashers the number 5 fuse is good I changed the round flasher still no avail .... any possible suggestions ?
Old 01-13-2018, 02:12 AM
pawpaw pawpaw is online now
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Welcome to FTE.
I see you don't have any replies yet so I'll see if I can get things started.
Good idea to have checked fuses, did the problem come about suddenly after some event?
If you don't have a FSM, repair manual, or wiring schematic, go here & log in BBB Industries - TSB's & Wiring Diagrams, to have a no cost look for any TSB's for related wiring & for the power & ground wiring pictorials for your model/year.
Do you have B+ power to the turn signal lamps filament when the signal stalk is activated/they light up but don't blink?
If they light up, look to the blinker to make sure it's the right one & to it's socket for corrosion or loose fit.
If the turn filament doesn't light up, back up toward the cab to the next electrical connector to see where you loose B+ to ground, using a 12 volt test lamp, 12 volt buzzer, or multi-meter on the 20 VDC range.
Seeing as how the flashers work, it sounds like the body B-/Ground connection is ok.
Some initial trouble shooting thoughts for consideration, let us know what you find.
Old 01-13-2018, 12:57 PM
Turn signals
I started looking around and didnít realize that the Rangers have 2 separate circuits 1 for Turn and 1 for Signals I had changed the flasher on the front side of the fuse panel and didnít see the back side that had the Actual turn signal flasher this solved my issue. Thank you everyone ! BTW the Forum Rocks !
Some initial trouble shooting thoughts for consideration, let us know what you find.[/QUOTE]
Old 01-13-2018, 02:47 PM
Ok good trouble shooting, feedback & to hear all now seems well.
1998 Ranger Turn Signal Issues. JMKiser Ranger & B-Series 5 04-20-2017 05:52 PM
No turn signals 1976 F150 Ranger boatordie 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-30-2016 08:44 PM
No turn signals 51camohunter 1987 - 1996 F150 & Larger F-Series Trucks 15 06-30-2016 12:02 PM
TURN SIGNAL / HAZZARD FLASHER ru67 1967 - 1972 F-100 & Larger F-Series Trucks 8 05-28-2016 01:21 PM
Turn signal problem Bradley Ripley 1999 to 2016 Super Duty 1 02-22-2016 11:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
