Installing cab - best way?
A bit ironic that currently Greg Rogers's post is about removing the cab!
Anyways, I'm at the point where I want to start putting a lot of the parts back on the chassis so I can get it to the shop to do the final parts - wiring, etc.
The cab seems like it's gonna be the hardest part. I have a lot of tools, but not many friends in the Irvine area, so any method that would require fewer people would be best!
Received 4,132 Likes
on
I did mine the same as John. You can see my cab reinstallation starting here:
https://www.ford-trucks.com/forums/1...l#post17604981
Ignore the picture with the chains, 2x4s, and come-a-long. That was before I had an engine hoist.....and brains.
on
on
Maybe this picture will give you a better idea , it was something I through together about an hour before I lifted the cab off the frame. This picture of course was one of the several times I had it on and off the frame. When it's lifted it stays level and balanced perfectly..
just
just
Everything is connected, making it one solid rig. The flat pieces on the end are connected to the 4x4s, not only tying them together, it forms a cradle to keep the cab from sliding off the ends.
I think the metal pieces are just a couple of angles to connect the end of the hoist to the middle 4x4. John will have to answer that one.
