1956 VIN Plate
1956 VIN Plate
I am trying to figure out what to put on a new VIN plate for my 56 F100. The old plate is missing. I do have a title with the # on it but there are other #'s that I don't know. I have 2 old plates that came off of junkers. One is off a 1956 F350 Wrecker that I parted out. The other is off a 1954 F600 that was in a scrap yard. The 56 F350 has " #" before and after the serial #. Has R for color which must be red because it was... Has production code of 12K270T. It also has two hashmarks("##") in the DSO spot. The F600 has "*" before and after the serial #. Has a "U" for color ( I don't know what color that is supposed to be). A production code of 16GLX1702. And it has 2 asterisks in the DSO spot ("**"). My questions are:
On a 56 f100, What should be the symbol before and after the serial #?
What is the color code for the medium green color?
What production code??? - it's different than the vin.
What goes in the DSO spot?
Thanks for any help you can give, Greg
The 56 F350 has "#" before and after the serial #. Has R for color which must be red (Torch Red) because it was.
Has production code of 12K270T (12K = assembled October 12, 1955). It also has two hashmarks ("##") in the DSO spot.
The F600 has "*" before and after the serial #. Has "U" for color (Meadow Green).
A production code of 16GLX1702 (16G = Assembled July 16, 1954). And it has 2 asterisks in the DSO spot ("**"). My questions are:
On a 56 f100, What should be the symbol before and after the serial #? **
What is the color code for the medium green color? (G = Meadow Mist Green / U = Meadow Green).
What production code??? Impossible to know.
What goes in the DSO spot? Usually nothing...see below.
Since there are no records available for these trucks from FoMoCo, it's impossible to know what the production code of your '56 F100 was.
An asterick was usually stamped before/after serial numbers (VIN's) on Rating Plates and frame VIN's. This was to prevent additional numbers being added by crooks.
Thru 1962: There is no DSO (Domestic Special Order) code unless the truck had no COLOR code stamped on the Rating Plate or SS stamped on the Rating Plate to denote a special non standard color.
Or if something special was added to the truck that was not an RPO (Regular Production Order) after it left the assembly line.
DGMFORD
15
05-26-2019 10:29 AM
alvald83
06-28-2010 11:04 AM
