Vacuum wipers - Page 2 - Ford Truck Enthusiasts Forums
Vacuum wipers
Old 01-11-2018, 02:48 PM
abe's Avatar
abe abe is online now
abe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant future
Here's a stock 56 Big Job engine with a compressor all decked out.
Old 01-11-2018, 05:17 PM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud of
Quote:
Originally Posted by Jeff and Nicolle View Post
I worked for UHAUL back in '89-'90 as a Mobile Repair Unit. There were big trucks that had air compressors belt driven off the engine. IIRC they were for the air ride suspensions. Might keep an eye out for BIG ORANGE and WHITE trucks in the salvage yards?
There is a local guy here, he has TRAIN horns under his raised bed. When he pulls the chain you see thousands of people jerk, twist, jump, fall, cuss, and look around! Not gonna lie...I laughed until I cried !
In some parts of the country that will get you the attention you deserve.
Old 01-11-2018, 11:50 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle is a splendid one to beholdJeff and Nicolle is a splendid one to beholdJeff and Nicolle is a splendid one to beholdJeff and Nicolle is a splendid one to beholdJeff and Nicolle is a splendid one to beholdJeff and Nicolle is a splendid one to behold
Quote:
My horns came from a Pinto...
Old 01-12-2018, 12:02 AM
All fun aside, I am interested in using my vacuum wipers also. I hope this sheds some light on the subject. My truck only had the drivers side wiper, so I will need to get the extra hardware for the other side, but that is a long way from priority at this point.
Old 01-12-2018, 06:36 PM
1948Dev's Avatar
1948Dev 1948Dev is offline
1948Dev is gaining momentum as a positive member of FTE.1948Dev is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Silver54 View Post
Hey guys, just wondering if any one knows proper amount of vacuum that the wipers require for a 55. Was hoping to purchase a little 12 volt vacuum pump to run them but not sure the volume per minute that would be correct for these.
Thanks
Don't know but even with a rebuilt vacuum motor, mine needed a well lubed linkage to successfully run two wipers.
Then you still have the issue with not wiping when you're on the throttle.
I fixed that deal with a Trico electro-vac, which is an electric vacuum pump that supplements the unsteady vacuum provided by the engine. Works like a charm. Provides enough vacuum to drag dry wipers across the windshield and places the wipers into the usable category when you're running down the road.
Old 01-12-2018, 07:03 PM
52 USCG Panel's Avatar
52 USCG Panel 52 USCG Panel is online now
52 USCG Panel has a very good reputation on FTE.52 USCG Panel has a very good reputation on FTE.52 USCG Panel has a very good reputation on FTE.52 USCG Panel has a very good reputation on FTE.
Yikes! I saw a Trico Electro-Vac on e-bay for $450. I was all interested in your solution, but $450 certainly dampens my enthusiasm.
Jim
Old 01-12-2018, 07:13 PM
abe's Avatar
Quote:
Jim
Jim, Rainex on the windshield is a lot cheaper, isn't it?
Old 01-12-2018, 07:27 PM
Rainex is good! My truck never had working vipers. Why should I all of a sudden feel I can't get by without them? I did send my wiper motor off to be rebuilt, however, and I do have a vacuum tank like the one Peter recommends. I'm getting soft and spoiled in old age.
Jim
Old 01-12-2018, 07:32 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.
The guy on ebay that has the trico pump for sale does not know what he has. Fuel injection??? Guess that is why it is $450. I paid $20. for one identical a couple years back that is available for the $20. price if anyone is interested.
Old 01-12-2018, 08:56 PM
1948Dev's Avatar
Jim
I paid $150 for it NOS on eBay in April 2017.
They do vary some in price. I've seen them from $80, all the way up. You can tell the NOS ones because they look 70 years old but have red plastic caps on the inlet and exhaust sides of the pump. They use Delco appliance motors too, which are very long lived for quality, so even a "used" one is
going to provide many years of service.
Wiper - Vacuum or Electric pezsox 1948 - 1956 F1, F100 & Larger F-Series Trucks 41 12-19-2017 02:36 PM
52 F1 original vacuum wiper 3twinridges 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 08-31-2017 06:39 PM
Vacuum Tank Placement roadrunner01 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 08-08-2017 12:36 PM
Wiper upgrade. Fyrfyghtr 1957 - 1960 F100 & Larger F-Series Trucks 4 10-28-2016 07:36 PM
Vacuum line diagram or help with vacuum wiper 50 F1 jb50F1 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 03-14-2016 04:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
